Wheel Alignment Question, Car Feeling More Skittish
OK I will try this.
Is there a combination of Caster, Camber and Toe for a R34GTR that works the best for a street car car.
Any help would be appreciated as I will be changing my tyres soon and would like to get an alignment that suites my car.
actually, first thing to know is that it is very normal to have nasty tramlining with such big tyres on the front....they ill tend to follow the road contours wherever they go. so there will be only so much you can do about that.
as for a general alignment, it is the same as any other car for road use. about 1mm toe in and 0.5 camber at the rear, and whatever you get for camber at the front, and toe in to match minimising tyre wear. caster and front camber is not adjustable standard
  • Like 1
OK I will try this.
OK here's my contribution - others may have a different view:
Caster 7deg
Camber 1.5deg neg Front
Camber 1.0deg neg rear
Don't know what toe would work on your car.
Although just saw Duncan's post and as he says not much is adjustable from stock parts - just toe in and and small amount of rear camber
BTW if you do have adjustable camber arms and have a lot of camber (say 3deg) dialed in it will tippy toe in a straight line and feel better on cornering.
  • Like 1
Thanks fellas
Started reading up on this and it seems a topic that has many different answers, maybe trial and error ?
The wide tyres seem to be a major factor to this problem and as I am going from the 255 to 265 it is going to increase this crappy problem. These country roads are fun but they want to pull you all over the place. Guess it is just keep your mind on the job :)
Had 255s on my 350GT RWD and nothing like it is with the R34GTR AWD
I will make some notes and ask them to do what they can to help when I change my tyres and hope for the best. But I will keep the work sheet and once I see how the cars reacting I will post it and love to minimize the tramlining :)
Do awd cars magnify this tramlining ?
Semi related, anyone know a good affordable wheel alignment shop in inner Melbourne? Like <$150 but who still know their way around adjustable arms etc.?
I know I know good and cheap are mutually exclusive but worth a shot
Like most things, I guess there is a combination that helps lessen the severity of the tramlining,at the wrong time it could be more than annoying :(
I wonder if having a Quaife front diff and modifying the tranny added to this problem as it seems a little worse now ?
Any good alignment shops in the MId North Coast ?
Any opinions of Bob Jane Newcastle. They were friendly and efficient but as an alignment specialist, I do not know.
As for good and cheap, I remember a lady back in the day that was worth a shot or 2 :)
Traction Tyres in Rowville.
x111111111ty.
Have read that Tyrepower North Melbourne are also good.
That'd satisfy the "inner Melbourne" part of your post ;)
  • Like 1
x111111111ty.
Thanks mate I'll give Tyrepower a go!
I've gone through a fair bit of different toe in/out and camber settings growing up. Big numbers are not worth it unless your in a V8 supercar race team.
I have learned the best setting and the easiest on your car is 0/0 toe on the front, and a touch of toe in on the rear for stability, I'm talking hardly any, just less than 1mm. The car will drive a lot more neutral and its easier on your wheel bearings and tyres. Just think toe in and out is making your tyres point in a different direction to the way they are spinning which is pretty ludicrous really.
As for camber, anything more than -1 in the rear will cause it to have less grip and oversteer in the wet like crazy. I had all factory suspension arms which had me at about 1.7 neg camber for some reason with stock springs, went to adjustable hardrace, set it to -1 and and got masses of more grip and stability from the rear.
You are talking about AWD ?
I am only learning about this and what you are saying is what I am starting to think is something to try from what I have read so far, or at least ask them about when I change my tyres and get an alignment .
I was going to ask if these guesstimations could help with the tramlining, front 0-0 toe , rear, very little ? very small amount of negative Camber -0.5 to -1
Castor I am not sure of this but maybe 5-6 Ds
Maybe what I am saying is crap but I have to start somewhere and still have a month or so before I have to do it :)
Zero front toe static will become toe out when the suspension is being pushed back by the road when moving forwards. Will still tend to tramline a bit. Probably still would even with some toe in. So not worth worrying about - you're not going to get rid of the tramlining. Zero toe at the front is a good recommendation.
All the rest of Sonicz' recommendations are valid, and it doesn't matter whether AWD or RWD either.
If you were trying to minimize tramlining for a street car how would you set the alignment
I think I will have the steering checked in case there are some worn parts.
Maybe when overtaking and being on a different road angle the alignment settings would be off, because the road surface is slopping the other way and this makes the tramlining feel more violent , if that makes any sense ?? ( I say this because I read that some alignments take the road slope into account )
Maybe it is the situation that makes it feel more violent ,especially when it pulls you towards the other car. Stuffed if I know, the more I read the more confused I am :w00t: LOL
get some adjustable castor bushes OR new castor arms, dial in around 8 degrees of castor and run some toe in at the front and toe in at the rear too.. I personally run zero toe at the front and 1mm toe in at the rears either side.
Thanks I will check out the castor situation after or when I am getting the new tyres on.
Bit confused with the Toe, you say run some toe and then tell me you do what I was thinking of doing and you run zero in the front ?
Interesting points, here is a set of suspension settings I was given (knowing very little about alignment, I've used them)
Are they ... good? Bad? Horrible?
Front
Camber = -1mm to -1.5mm
Castor = +7 deg
Front toe = 0 / Zero
Rear
Camber = -0.75mm to -1mm
Toe = -2mm in on both sides
Noone ever questioned these settings (incl the suspension shop I provided them to)
Still keen to hear if they're good/bad/indifferent/you'll get 1000kms out of a set of tyres on them, etc
To minimise tramlining you need to minimise wheel camber and run less than zero toe (ie, run a little toe in). Caster I'm not so sure about. More caster gives a stronger self centering effect to the steering, but whether it has a strong effect on tramlining behaviour is not so clear to me.
EVERY street wheel alignment would ideally take into consideration that we drive on the left hand side of roads that have camber. Therefore you want to set the front caster angles such that the car wants to pull to the right ever so slightly, which is UP the camber, to stop it wanting to drift downslope and off the road. Of course, when you're on the other side of the road overtaking, then the wheel alignment and the road camber are going to work together to make it pull to the right. But that shouldn't be confused with tramlining. Tramlining is where the tyres grab hold of profiles in the road surface that are at a smaller scale than the road's main camber profile and then steer the car.
Be aware that R chassis cars are not designed to have that much caster wound in to them and it loads up the bushes in the upper and lower arms a lot. Worse on R32s, but still an issue on the later cars.
He was suggesting that you run some toe-in in order to minimise tramlining behaviour, while saying that he runs zero toe (because he doesn't care about/suffer from tramlining).
Front
Castor = +7 deg
Rear
Those settings are fine except I would use less toe-in on the rear. That amount of toe-in will make the rear very stable - it will drag the rear end around like an anchor.
The only other thing to say is that hopefully the camber numbers front and rear are actually degrees, and not millimetres, because degrees make sense and mm don't.
Edited by GTSBoy
  • Like 1
As my next alignment is free I am thinking of trying
Front
Toe = zero zero
Camber = Zero Zero, or very little
Castor = + 6 deg
Back
Toe = zero zero
camber= zero zero, or very little
castor =+ 6 Deg
Drive it and see how it feels and then I have something to work off so I can tell them how it is driving,then go and have it done by a quality shop , :unsure: :unsure:
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
