Sau Vic 2014 Motorsport Championship Final Round - Pi Sunday 28Th September
I was not expecting that hum from the A050's, never used semi's before. The drive home was unpleasant to say the least. Will stick with the AD08R's for a while though, plenty more time in them.
Semi-slicks have high road noise. Not really ideal for driving on the street, they will wear out quickly too.
it was more a case of fed up with changing wheels again - does sound like he'll make the effort if he runs them again.
Dave, when I get a chance, will load up data and give you a shout.
Yeah I know what that's like.. changing wheels is a hassel if your track car is also street driven. been there done that :)
Thought I was used to road noise with my tin can, country roads are fairly horrible on the AD08's as is. As John said I cbf'd changing them as I was gonna get top gear'd lol.
Not sure I'll bother with semi's just yet, still plenty of grip on the AD08R's. I reckon I can get into the 56's with them, maybe even a 55 which is plenty fast enough for now.
John, how much work is involved in sync'ing the videos and data? I find racerender with just one video and the data a complete pain in the arse to line up.
Pretty easy with Racechrono on android (Nokia app would only extract data from full laps), later android app exports the whole dataset so you've got the 0kph data take off point to match with take off movement on the videos, then just trim the boring stuff away - this last point is subjective, if I'm too aggressive, I'm left with no video :-)
Also, check out this site - https://serious-racing.com/
You can upload GPS data from various apps and loggers to compare 4 of your own laps or one against up to 4 other people. It's pretty cool. I'm on there as my username here (as is Aaron).
tried to create an account couple of days ago, never received new account confirmation email, gave them a poke, we'll see?
BTW Did the championship table get ratified?
Their site had issues with hyphens in the user name first time I tried, guy that runs it sorted it out though.
Championship results were left in the hands of the committee not long after the final PI round but no further updates required that I'm aware of.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
