I have a 1993 R33 Gtst series 1 which I bought in June, the engine and ecu are completely stock (hard to believe I know) and the car runs completely fine... most of the time. About once every few weeks it will have a spasm and will not let me go past 2 and half rpm on any gear and jerks violently as if the revs are too high and just cuts the accelerator power once it tries to go past 2 and half rpm.
I am thinking along the lines of something to do with the turbo or maybe AFM, I was just wondering if this has happened to anyone else or if it is a common problem and if someone could offer me some ideas with with how to fix this problem.
Any help/ ideas/ input would be appreciated.
I have 2 videos I recorded today of this occurring but am unable to upload it as it is in mp4 format and am not sure how to convert it so it can be uploaded.
https://www.sau.com.au/forums/topic/448542-whats-wrong-with-my-r33-please-help/
Sounds like an afm issue especially and the lower spectrum of the rpm. If you're handy with a solder you can crack it open and soldier all the joints inside it. Its not likely the element is damaged but more likely there's a cold solder in there. If that doesn't fix it then it might be a long road.
OP, post up a pic of the inside of the AFM if you want some opinions. The top of the box part is just glued on, bit of mucking around with a knife etc to get it off but not so hard. Should be able to see the problem if it needs a joint or 2 resoldered
it could be surging due to clogged injectors, run a $10 bottle of injector cleaner through your tank, fixed mine with similar problem and even if its not the problem at least you will have clean injectors
if it is the afm you may not see an obvious fault in the circuit board cos it could just be a dry solder joint so just hit each pad with the iron to make sure the pad is good, but i still think you should try injector cleaner cos it fixed my similar problem
No it's not a burn hole, its just glue.
So I ended up just re-soldering the 4 connection pins which you can see in the 3rd photo because I could see one of the pins looked like it wasn't connected properly. Hopefully this fixes the problem but it will be hard to tell because it was a rare occurrence in the first place.. so time will tell.
I like your idea of injector cleaner too Mick, I might do that as well since it's cheap and can't hurt by giving it a go also.
Thanks for your help gents, I'll let you know how it's going in a few weeks time.
After re- soldering those 4 pins in the AFM I've been driving around Sydney quite a bit and the other day I drove Newcastle and back. My problem is fixed!
Thanks for the help!
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
