  • Replies 41
yeh was a good night, well done to Dr Drift on beating the bresciani Vl, only because it got 5meters off the line and broke something but still a win. lol
Also congrats to a friend of mines bro whos Rabjab Purple VL ran a 10.31 @ 131mph
Mesh mesh, you get any good times in the GTR i saw one run but i dont know if it was a 13 something or a 12 something cause those Calder Park timing boards are fcked.
Hi SLY,
it was my first time.. so i'll put it this way.. my 60ft was 6sec "yes 6~sec", my time was 15~sec "yes 15~" the car was misfiring the whole way, and I did 112mph.
:cheers: hopefully we'll go again next week, and bring the some other cars along aswell... Now just need to find someone who can friggin drive [looks arond]
Spent most of the night watching cars blow up
2 runs for the night high water and intake temps and easy launches saw
12.6 and 12.3
then rain  cancelled the night
Saw you run... very impressed, what have you done to it, looked like you were moving hard! What was your MPH?
we decided not to run it, coz didn't wanna look like tossa's. But after seeing the 2 mercs "S600 (13.0) & E55 (12.4)" there last night, we might take it next week.
Nothing tossa about running a mid 12 in a family saloon. What's with the 6 second 60ft, I remember the night at the karts you were the king of launch control :cheers:
It is not my car i just helped build it
umm if you want to see what it has come and have a look next week @ calder and ask us to pop the bonnet
245 rwkw on 15psi pump fuel street tyres full street trim 11.92 @ 115 mph is best so far don't know what mph was run last night as i didn't get there until those runs were done.
Hey rrrage, those RYVE numberplates that you blanked out aren't real numberplates... Ryan would probably prefer that you didn't blank them out! ;)
andrew is there some reason he hasn't tried avgas in it?
it would be interesting to see if it makes a difference.
AVGAS? its a street car running mobil synergy 8000
we might play with some sunico or c16 once the boost is wound over 20 psi ;)
andrew: hopefully I'll see you there next week.
SLY: wow 11.9, I think that car has a chip & and changed supercharge pulley. Yeh my 60ft time was wacked because later I found out I broke the line and the time started, but me was still sitting there "having a fag, talking to the misses on the mobile ;)" waiting to go!!...
I wonder if benm will let me add my slip to his collection?? Now that should be something.
I had a great night, something about the colour YELLOW, that yellow Monaro was f*&king awesome, that YELLOW rotary RX4 that nearly lost it on the track, bresciani's YELLOW VL blowing his "I think TURBO"..
Hey rrrage, those RYVE numberplates that you blanked out aren't real numberplates... Ryan would probably prefer that you didn't blank them out! :)
bah i cbf changing it back now ;)
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
