Oil Leaking From Between Head And Block
Sorry for the poor quality photo, had to enlarge it greatly but you can see where a smear of 3-bond is needed to stop oil leaking from the camshaft section of the head out to the cam belt section. Oil can weep between the cam cap and the head unless there's a smear of sealant applied.
Easiest way to do this is after the cam is installed but not yet torqued down.
As mentioned I also wipe a smear of 3-bond to the seal's outer as they're quite a loose fit.
I couldn't find any mention of this in my workshop manual, but it's pretty basic stuff.
Any original Rb I've stripped has had a nice deposit of sealant in this spot.
Okay thanks guys will try this. Someone has already PM'd me and said to do this also.
My genuine Nissan service manual makes no mention of applying any sort of sealant to either the cam caps or the cam seals upon installation.
The sealant I have been using is a permatex ultra blue RTV silicone gasket maker.
No I was using my R32 printed engine manual as I lost the R34 one when my computer died. Both RB20/25/26 were the same but none of them had VCT so that may play a part in it.
Greased seals in with no sealant under front cam caps results in no oil leakage when engine is running but when I turn engine off it leaks oil.
Weird.
The manual I have definetly calls for the sealant. The nissan sealant is pretty much threebond from what I have seen. The orange threebond is the best but grey is fine as well. Can't remember what number/name they are though
Any chance you rebuilt the head before assembling the engine?
Did someone knock out the oil gallery plugs front and back and change to bspt/npt plugs when cleaning out the head properly? Sometimes if they aren't sealed up nicely when fitted oil can leak past them and run down and around.
It's probably not the case, but it's another possible cause unless your head is unchanged, stock form and you are certain you have identified the front cam cap area as the point of egress.
So it still leaks. First time I have had it out in the sun and now I notice that it also leaks down the side of the block not just at the front of the engine as well.
It leaks from the intake cam right around to where the second runner is on a greddy forward facing plenum, so between cylinder 1 and 2ish. Peoples thoughts on if it is still the cam seal that is leaking that it would be able to reach back around the block that far? I have thermos that push a fair bit of air so not sure if they would be able to blow the oil back that far.
n the side of the engine it looks like it's leaking from the block but at the front it's still leaking from higher up because the oil is running down the head to where the VCT solenoid is. I have put a small amount of liquid gasket on the VCT solenoid thread and also put an O-Ring in as it has a taper that looks like an O-Ring is supposed to go there.
Thinking of removing VCT solenoid and blanking it with a bolt? Will give a lot more visual access to try and identify leaking area.
Welded VCT feed in head and DID NOT block the existing VCT feed in the block. I'm thinking now that I definitely should of done this. Also running an RB30 cometic metal head gasket.
Any advice/thoughts appreciated at this stage. Supposed to get tuned next Friday :(
Did you weld the vct gallery or plug it?
What gasket did you use?
30 or 25?
RB25 Cometic Multi layer metal head gasket and RB25 ARP head studs.
So now using a 30 gasket i think. Keen to find out the reason why only oil is leaking.
Edited by Stagea97
Based on the above quotes I am confused?
What vct feed in the block? The 30 block doesn't have a vct feed.
For reference for others, the 30 gasket is correct for the 2530 setup. The 25 won't seal by much around the coolant gallery around the front. It is only a few mm.
Sorry have been preoccupied with other issues. Yeah my mate cracked the rocker cover putting it on but it doesn't leak.
Turns out the external VCT feed line was leaking. I blocked it off at the block and nothing leaked a single drop of oil. Only ran it for 5 minutes but beforehand it leaked straight away.
Don't think I can be bothered taking the cam gears off again to fix it. Probably just run without VCT.
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
