Plenty of people run without VCT so is it really that detrimental to the cams? Keeping in mind I have a Neo head which is different to R33.
And I have absolutely zero motorvation (pun intended) to do anything on the piece of shite at the moment.
I know that and I completely understand why, yes VCT is very worthwhile. Only a few months ago I would have said anyone is crazy not keeping VCT. But in my situation I am very time restricted and have zero drive to do anything on the car at the moment.
  • 2 years later...
sorry to revive the thread i have the exact same leak happening on my car. I am about to pull the head off and redo it. The engine is a 25/30 too and im not sure if the previous engine builder made a feed to the cam journal. So I thought id check that while the head was off.
what was the root cause to the oil leak?
It was coming from where my 'fabricator' had tried to weld a fitting to the head for the external VCT. That head turned out to be junk and I had to get a new Neo head. The second head was then tapped and died and a fitting screwed in instead.
Where exactly is yours leaking from? And how is your external VCT feed setup
  • Like 1
I too have a similar situation but mine appears to be from the rear passenger side.  I have noticed a bit of oil around the front cover but it doesn't drip from there at all. Haven't looked into it much as i have walked away from it and other things for a bit. I re torqued my head just to make sure and used a rb30 mls cometic 1.3mm head gasket. Head was fully refurbed by a head shop and block was also machined sqr to deck  when built to get 100% 0 deck height and blue print it.
The issue is that I bought the car with an RB25/30 built engine.The sneaky bugger must have washed it off or something before I inspected the vehicle.
I've attached a picture below of what it looks like. I'm hoping it's the shitty blank off that's been used. If that's the case it will be an easy fix.
On 3/11/2017 at 4:30 PM, Borci88 said:
Are you sure it's not just a leaking cam seal Bryce?
I'm hoping its something minor like that. It would suck regardless having to replace cam seals. Ill start by replacing the blank off to see if that solves the issue.
  • 2 months later...
Can someone tell me the right 3-Bond to use.
I'm going to be attempting this tomorrow. Would rather not undo the cams. I know it's dangerous and could snap the cams. But has anyone taken off the front cam caps to ad sealant without snapping the cams?
So I took off everything to get to the cam seals and this is what I found.20170527_163835.jpg
Seems to be oil leaking from both seal. The backing made this more evident as you can see from the picture. Now following the advice posted here. The front cam cap should have a bit of sealant on it. There isn't any on this head. So I'm just going to use Ultra Black RTV on the mating surfaces. I couldn't find any 3-Bond orange. 20170527_163742.jpg
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
