R34 Gtt Brake Improvement Without Breaking The Bank
My mate makes them for 34
I have one on my car and use it for the track on my 34.
He will ship to you, my bro has a cusco one which is what this one was designed around.
http://www.gumtree.com.au/s-ad/hamersley/brakes-suspension/r34-r-33-c-34-master-cylinder-stopper/1057636608
Thanks Jake that looks like what I'm after. I've contacted the seller, hoping to hear back soon.
Just reading through this. Some great info here.
Just a question - Would it be so crazy to run two separate pads? Something more aggressive for track days and swap them back to a street pad when you're done? or will that cause issues with wear?
Not crazy at all, a lot of people do that.
However, I just found this yesterday, from Brakes Direct (GSL RallySport): The importance of machining or replacing rotors when changing pads
Basically if you go from one compound to another the recommendation is to machine the discs - not really feasible for just a track day or mountain run here and there.
Plus I doubt you're going to find separate 'street' and 'track' pads that would be of a similar enough compound?
After much contemplation I've decided to go with Remsa, I was really tempted by A1RM but I don't want the rotor wear or noise. Plus, it really is a street car at the end of the day.
  • Like 1
Thanks for the tip mate, this arrived quickly and seems like a quality part. Very easy to install, here's how it looks in the engine bay:
Haven't driven it in anger as yet, will report back once I do.
This is about half price compared to the Cusco item and I doubt Cusco is twice as good ;)
I grabbed one new of UAS a while ago in black for a similar price, does the job :)
I was considering doing an the evo brembo upgrade, alphaomega do a dogbone kit to fit evo brembos onto 355mm evo 10 rotors.
Not a bad option considering you could get it done for under $1500.
Tonba has a set of callipers up for sale on here if you are going down that path, the car has seen little use so they should be pretty mint.
I've already just painstakingly painted + purchased slotted rotors pads and lines. too late now. Stocker R34 brakes seem to hold up quite well for casual track duties it seems?
Edited by owen1r
Correct, with the right pad combo you can make them work real well actually!
Mine stops pretty hard now with the Winmax pads and DBA4000 rotors... They are chewing rotors but they have survived 4 track days now and still pull up hard... Will do one more Wakie day and then re-evaluate my braking needs as the car is predominately seeing circuit work these days, bugger all street duties...
I've got DBA 4000s and A1RM pads seem good so far but will be tested on my first ever track day on the 22nd of Nov, however since bleeding the brakes they intermittently have a soft pedal... even after bleeding 4 times over!
Edited by owen1r
You still have air somewhere mate, check it again.... Soft pedal indicates air in the lines probably....
I ran A1RM for ages, but once i started doing track in the heavy 34 they didnt hold up very well,,,, Burnt 2 sets of pads in 60 laps at Wakie :(
I take that this is for fronts only? I'm not too hot on 'mismatched' fronts and rears due to potential brake bias issues..
Anyway back to the original plan, I've got the following kit ready to go on the car, just need to find the time:
  • DBA T3 4000 Club Spec slotted rotors
  • Remsa pads
  • HEL braided lines
  • Nulon Xtreme Performance Super Dot 4 fluid
Will report back once it's all on.
  • Remsa pads
  • HEL braided lines
Yes only the fronts, I'm sure you could get some GTR rear brakes and paint them the same colour. If I bothered changing calipers I'd probably just go straight for stoptech/alcon ect.
Talk to the guys running bigger front brakes, like Richo etc... No brake bias issues with the big fronts and stock rears... As long as the pads and rotors are a similar spec you should be fine! When i go for the upgrade the rears will be staying stock...
  • Like 1
I'm just in the process of installing the rotors and saw this in the DBA instructions:
7. Fit new disc rotor to hub making sure it is indexed to a point with minimum run-out (using a dial indicator)
Do you guys normally do this? Is there a way to do this with feeler gauges?
How would you measure run out with feeler gauges?
You measure run out by setting up a dial indicator so that it is normal to the surface of the rotor, find the longest extension of the indicator (by slowly rotating the rotor until you find it), set to zero and spin the rotor. The run out is indicated by the measurement on the dial. Doing this with feeler gauges would means having to bolt some sort of straight edge contraption across the face of the rotor, somehow. Mounting a dial indicator is bad enough sometimes. This would be horrible.
You can quite possibly do it by eye. If you cannot see much runout in any indexed position then they are probably all good enough. If one looks better than the others, then go with that one. You can use a pointer of some sort to help with the eye calibration.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
