4 hours ago, Dose Pipe Sutututu said:
I highly doubt the A1RM are rated up to 780 deg. C.. if so why the heck do they crumble like a cookie on the track and the likes of Intima SR and Project MU HC+ / HC800 pull up fine - and both are rated much lower.
The 780C came from this QFM page: http://qfm.com.au/page/6/Performance_Range
3 hours ago, admS15 said:
I just finished off my first set of a1rm at Winton yesterday. Copped solid abuse for six sessions from start to finish, no cool down laps, last session was 10 laps and best lap of the day was on that lap. Pads where 50% at start of the day, didn't crumble but wore them right down. The rears where qfm hpx and they didn't like that treatment, they ended on just about metal on metal. In saying all that, at more demanding tracks like sandown, I don't think they will go too well. They are ok for the not so serious track car but it's the old saying, you get what you pay for and since I got another set for $60 for the front, I have put another set on the front. I measured the disc and compared to the measurement I took when they originally went on and the wear was 0.6mm. I thought that was ok. 4 track days, 1 set of pads, 1 set of tyres and 0.6mm of disc. Budget racing brahemoji3.png
Thanks, good to know!
I need something that can take the Sandown 200->90km/h punishment down the front straight repeatedly, and I'm tossing between Intima SR or Forza FP3 as a step up from Remsa.
I got some R33 GT-R OEM brake ducts off a forum member (thanks!).
I went to measure them tonight and they're pretty hefty, the height is 50mm. I'm already height challenged in the front so mounting these beneath the undertray/liner is most likely not an option..
Does anyone run similar brake ducts in their R34 (GTT or GTR)? Is there any chance to squeeze these above the liner somehow?
Otherwise I might have to set up vents and soft ducting from the fog light openings. It's a series 1 front bar.
  • Like 2
  • 4 weeks later...
I just finished fabricating some front brake air guides over the weekend, made out of 0.9mm galvanised steel. The design is largely inspired by the UAS ones (thanks dan.1337 for the photo and link!) but also looking at the OEM GT-R V-Spec ones. The most time consuming part was testing a number of prototypes at varying levels of lock and suspension compression to ensure that everything clears at all times.
What do you guys reckon, should I make some for the rears too? I cooked my 650C pads in all corners last track day (granted not enough cool down laps). I have since had the rear heat shields removed too, which hopefully cools rotors more evenly but will probably heat up drive shafts/boots/suspension components more now...
Also the R33 front brake ducts won't clear at my ride height so I'm thinking of adding just some rubber 'fins' on the undertray to channel more air towards the air guides. Might be an overkill.
Here's some photos of the front brake air guides (car jacked up, suspension fully expanded), yet to be painted:
Front left with steering straight
Front left with full lock in
Front left with full lock out
Rear right with no heat shield
The prospective air guide would follow the curve of the lower control arm edge I imagine and feed into the small gap between inner edge of the rotor and the handbrake assembly?
  • Like 3
8 minutes ago, admS15 said:
Thanks man! A lot of the ones you see around tend to cool the disc face, I like the UAS style as it feeds inside the disc to allow the vanes to vent more effectively.
Also quick tip for anyone wanting to give this a go: the jigsaw with a metal cutting blade was a revelation after initial struggles with tin snips...
that's really cool!
did you just use those U bracket things (those brackets to hold up conduit) to attach it?
Lol :)
Yes three mounting points: 8mm bolt at the hot end, widened 25mm conduit bracket in the middle, wide cable tie in front. I'll try to get a photo from the back later.
Here's how the front right looks from the inside, you can see the three mounting points:
6 hours ago, mr skidz said:
We need to make a mould and carbon fibre those things they'll sell like hotcakes
Or maybe someone can scan them and produce them on a 3D printer.
Could work but probably over-engineered :) It's just a flat sheet cut up to right dimensions and bent. I might look at doing a template if these work at Sandown next week ;)
Both front and rear air guides went well at Sandown today, with no ill effects. No brake fade but I didn't get any good runs in either as I had to nurse the car, pretty sure the head gasket is gone :/
Here's the rear left mounted:
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
