Hi guys, just wondering what are some good options for an R32 GTR turbo upgrade (based on your experience).
Car is a 1992 model and I soon want to get rid of the stock turbos.
Current Mods:
- Trust intercooler
- HKS hard pipe kit
- Alloy 52mm radiator
- Aftermarket front pipe into aftermarket 3" cat back exhaust
- PowerFC with hand controller
I was looking at some 2860 -7...just need other opinions.
My future goals for now is around 260kw atw on low boost setup. With a responsive turbo spool.
Preferably around $1,200 budget.
Thanks.
https://www.sau.com.au/forums/topic/448614-r32-gtr-turbo-upgrade/
Read -> http://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/
-7's will get you just over 300kws
-9's is the SAU preferred
look at $2500 plus fitting
Ps. Keep your standard camshaft but get some cam gears.
Edited by Sinista32
if you want to do it on a budget look out for some second hand t28 silvia or pulsar turbo's. these make a good upgrade and if you are patient you could probably pickup a couple from those guys who have upgraded their stock ones.
that $1200 budget will get you a set of 2nd hand -7's pretty easily.
Swap them out yourself and - I can't believe i'm saying this - run the car on your current tune while you save for a re-tune.
A fuel pump would also be a good idea
Thanks man, yeah that plan sounds good. Saw a pair of near new going for $1200.
I snapped my -7's up for $1100 a couple of years ago. Swapping them yourself is a bit of a pain but it's doable. While your at it, find yourself a set of R34 dumps if you don't already have after market ones and you'll be well on your way to 300kw.
