Hey guys,
Thinking of heading to WTAC 2014 at Sydney Motorsport Park this year?
I and a few others have / are thinking about entering our Skylines in The Lowdown.Com's Show n Shine on the Saturday (18th of October). I've listed my car as being part of SAU / Skylines Australia NSW, and I think it'd be great if a few others can help represent the club with their awesome machines. It also means you get to park nice and close to the stands!
Details from TLD's Facebook page:
It's on again ladies and gentlemen! The Motographics Show 'n' Shine at theWorld Time Attack Challenge 2014 is proudly presented by THE-LOWDOWN.com this year!
To reduce waiting time and traffic, this year ALL entries are required to be approved and accepted PRIOR to the event. We will not be taking entries on the day.
To submit your car for approval, click the following link and fill out the form. Don't forget to attach a few pictures of your car to ensure you don't miss out!
Entry cost per vehicle is $10 upon approval.
ENTRY FORM: http://bit.ly/wtac-show
FIRST ROUND APPROVALS: Monday 15th September
SECOND ROUND APPROVALS: Tuesday 30th September
FINAL ROUND APPROVALS: Monday 13th October
Approval to the Motorgraphics Show 'n' Shine does NOT include General Admission into the event. This needs to be purchased separately. The $10 Show 'n' Shine fee is purely to secure your vehicle for display.
GENERAL ADMISSION TICKETS: http://bit.ly/wtactick
The show kicks off at 9AM on Saturday 18th of October - Further information regarding arrival times will be submitted to approved entries in due course.
https://www.sau.com.au/forums/topic/448676-w-t-a-c-2014-show-n-shine-18-oct/
Yeah... how many people have entered as being part of SAU / Skylines Australia NSW so far? I am thinking of entering if theres a few more peeps (dont want to be alone) and if its not too late to enter yet...
I think we got until Monday 13th of October
Robbie Goddard's R32 GT-R "1 OF A" (which took out best R32 GT-R at the Anniversary event earlier this year) should also be entering as part of SAU.
If it is anything like TLD Showcased a couple of years ago, they just allocate us enough parking bays for the no. of cars entered. We didn't have a banner or anything like that, at that event. Unless the Execs want to get in on this; there won't be any signage or anything. So it wouldn't look quite so pathetic in the event only a few cars turn up and represent the club -> It'll just be a few great looking GT-Rs parked amongst each other.
if we enter under the SAU name they will just group all the skylines together and make it prettier.. we wouldnt be doing any leaflets under wipers like all the other stance clubs getting around
  • Like 2
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
