it says bump out time is 4:30pm.. if i need to leave early that day incase of a emergency am i able to leave ? this seems abit strict
you will be but u will have to negotiate your way out which may be difficult if theres a number of cars and spectators..
sup from mexico, see ya'll there fellers.
bringin your 4 door with you? :)
btw this is how the dirty old lady currently will look on the day
Let's agree to a meeting point, I'll probably grab brekky from the maccas on Great Western Highway minchinbury before going to the meeting point, if anybody is heading from Penrith direction we can meet there & head down as a group?
  • Like 1
I think its just you and I from the riff big boy
:touch:
OK so called Homer's and they will be open from 7:00 am. That's when I'll try to be there.
I'll pretty much have to get to bump in time at EC right at 7am.
Forgot my dad is flying back home on saturday & his flight is at 12:30pm, so planning to park first thing, get picked up from EC & come back afterwards.
Anybody else gonna be at the gate at 7am?
Do the organisers allocate where each car parks or do we have a bit of free play in our club area?
See you there people :)
ill more than likely be waiting for you all just inside the gate to the track because im a lazy slack arse
Hey mate! I might do the same, coming from the central coast so I might just meet you all there dave can you pm me your number? :)
  • Like 2
I will do the same then
I'll just ask the organisers/traffic marshalls where our club section is & head straight there, planning to be there right on 7am
once the main group rocks up we can worry about the arranging cars :)
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
