How long is that group buy pricing available for Pete?
Only just found the thread... wish I found it a couple of months ago :(
Just about to pick up my 32R from tuning with -5s on e85 flex fuel setup, but would happily send it back in to the workshop in the new year for vcam style setup...
Cheers
  • 4 weeks later...
I just realized that using this method it would be possible to also add vct to the exhaust cam.
Of course it would need an actual exhaust cam and would double the price but surely it would be good.
Also would be able to add vct on exhaust to rb25s.
The other obvious thing is the requirement for an ecu running a crank trigger.
Cmon someone. Do it!
i asked that a few months ago and the answer was yea that would be easy
problem is it costs alot and they only sell a few of these
  • Like 1
You may know the answer to this. Is the nose of a RB26 cam the same as a RB 25 cam? If it is, I wouldn't mind using the cam I have in there ATM (260 at 10.85), that way I wouldn't have to reset clearances again.
I might take a treck out there and see what the results were.
Can update that the Unigroup car that this kit was being used on was just about to have the cam covers bolted back into place after install. Hopefully next week they have an overlay.
Basic setup was a 2.6, 6266 open scroll, 250 @ 9.15 exhaust cam, E85.
  • Like 1
  • 4 weeks later...
  • 1 month later...
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
