  • 2 months later...
I just bought the stage 1 otomoto kit for my 2.8 'baby' stroker with -5's. I staying with 98 octane pump fuel so I'll need all the help I can get out of my 'street' setup.
I have a couple of neo vct units and a neo solenoid laying around from my 'poor mans' v cam idea, so they will be perfect for this kit.
I'll try to get some results/comparisons once I've fitted it. I'm running a PFC so I'll most likely go a jaycar style rpm switch controller to control the solenoid.
  • Like 3
  • 1 month later...
  • 2 months later...
So this is the latest. Got sick of waiting for months for my replacement head to come back from a business I tasked with machining for bigger intake valves and port clean up, so I'll be leaving the old one on. It's already lightly ported and has aftermarket springs/retainers.
After 11 years of running GTR's and twin turbo's I'm going single heheh.
Also got a haltec plat ecu so that will control the vct solenoid.
post-12712-0-13048300-1448962005_thumb.jpgpost-12712-0-56213000-1448962015_thumb.jpgpost-12712-0-05462400-1448962030_thumb.jpgpost-12712-0-33919400-1448962043_thumb.jpg
  • Like 2
I bit the bullet and went ahead with it:
http://www.sau.com.au/forums/topic/251820-got-over-400kw-atw/page-164#entry7633312
Have to sort out my clutch before I can wind the boost up again
  • Like 2
  • 1 month later...
Man I want this.
I'm only going -9s so they'll be out of puff at 320-330rwkw anyway on 98, bu the extra response (on an already responsive turbo) and torque would be nice.
How did you go Sean?
Edited by ActionDan
  • 3 months later...
So got it tuned with a t51R first= lag monster but was sorta driveable. Sounded awesome revving to 9k rpm...plus screamer heheh, 550WHP @20psi.
Then went back to -5's and got it tuned again. Wow midrange is great and pulls well from down low! (stroker helps there)
What I've found and Yavus at Unigroup already knew is that the 260deg intake cam supplied by otomoto is too big in duration.
I ended up switching off vct at 7000 rpm as that is where it starts to drop off. So (in theory) you could leave a 260 deg cam for example at 20 or so degress advanced on you adjustable cam gear and only nose over after 7000rpm lol!
Max I rev my setup to is 8-8500 rpm so you get 1000-1500 rpm of extra power for $3000...
They need to (otomoto) sell an intake cam that has a shorter duration of say 242-248 degrees to bring down the switch over point and move the whole graph to the left a bit more :)
More development necessary before I'm 100% happy with setup, but in the mean time, in short it's a beast heheh.
I'll post a graph up soon. Don't worry about HP as dyno is a tuning tool heheh. I'll have to take it down the strip to see what MPH it pulls :)
  • Like 1
  • 2 years later...
  • 4 months later...
On 2/2/2019 at 1:20 AM, kaylafat said:
hello,
is it worth to use this VCAM kit on an rb26/30 with a EFR twin scroll turbo newest generation?
Yes
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
