  • 2 months later...
I just bought the stage 1 otomoto kit for my 2.8 'baby' stroker with -5's. I staying with 98 octane pump fuel so I'll need all the help I can get out of my 'street' setup.
I have a couple of neo vct units and a neo solenoid laying around from my 'poor mans' v cam idea, so they will be perfect for this kit.
I'll try to get some results/comparisons once I've fitted it. I'm running a PFC so I'll most likely go a jaycar style rpm switch controller to control the solenoid.
  • Like 3
  • 1 month later...
  • 2 months later...
So this is the latest. Got sick of waiting for months for my replacement head to come back from a business I tasked with machining for bigger intake valves and port clean up, so I'll be leaving the old one on. It's already lightly ported and has aftermarket springs/retainers.
After 11 years of running GTR's and twin turbo's I'm going single heheh.
Also got a haltec plat ecu so that will control the vct solenoid.
post-12712-0-13048300-1448962005_thumb.jpgpost-12712-0-56213000-1448962015_thumb.jpgpost-12712-0-05462400-1448962030_thumb.jpgpost-12712-0-33919400-1448962043_thumb.jpg
  • Like 2
I bit the bullet and went ahead with it:
http://www.sau.com.au/forums/topic/251820-got-over-400kw-atw/page-164#entry7633312
Have to sort out my clutch before I can wind the boost up again
  • Like 2
  • 1 month later...
Man I want this.
I'm only going -9s so they'll be out of puff at 320-330rwkw anyway on 98, bu the extra response (on an already responsive turbo) and torque would be nice.
How did you go Sean?
Edited by ActionDan
  • 3 months later...
So got it tuned with a t51R first= lag monster but was sorta driveable. Sounded awesome revving to 9k rpm...plus screamer heheh, 550WHP @20psi.
Then went back to -5's and got it tuned again. Wow midrange is great and pulls well from down low! (stroker helps there)
What I've found and Yavus at Unigroup already knew is that the 260deg intake cam supplied by otomoto is too big in duration.
I ended up switching off vct at 7000 rpm as that is where it starts to drop off. So (in theory) you could leave a 260 deg cam for example at 20 or so degress advanced on you adjustable cam gear and only nose over after 7000rpm lol!
Max I rev my setup to is 8-8500 rpm so you get 1000-1500 rpm of extra power for $3000...
They need to (otomoto) sell an intake cam that has a shorter duration of say 242-248 degrees to bring down the switch over point and move the whole graph to the left a bit more :)
More development necessary before I'm 100% happy with setup, but in the mean time, in short it's a beast heheh.
I'll post a graph up soon. Don't worry about HP as dyno is a tuning tool heheh. I'll have to take it down the strip to see what MPH it pulls :)
  • Like 1
  • 2 years later...
  • 4 months later...
On 2/2/2019 at 1:20 AM, kaylafat said:
hello,
is it worth to use this VCAM kit on an rb26/30 with a EFR twin scroll turbo newest generation?
Yes
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
