Hi Guys,
As the title states, I am chasing the panel/s that sits behind the rear number plate of the ADM R32 GTRs and whatever bolts or brackets are necessary.
Does anyone have one, or know of anyone who has one, whether its a reproduction or genuine that isnt ridiculously expensive?
Not fussed on colour as I can have it sprayed.
Cheers
Damo.
  • 4 months later...
  • 1 month later...
ADM R32 GTR******************************** that isnt ridiculously expensive?
never seen those two lines work in the same sentence before.
Isn't the whole thing wider to suit Aus number plates? and will not fit a JDM model?
That's why the rear lights are completely different on ADM models.
i didnt think the lights were a different dimension. they just dont have reverse lights by the plates.
i dare say you would need a whole rear bar though.
Edited by GH05T
I wana get rid of the reverse lights and custom make a reverse / indicator light where our normal indicators are out of leds.
Hence why i want that plate to make it look pretty and fit a number plate properly.
  • 6 months later...
Guys, I am still chasing one of these.
Does anyone know of any one that has one for sale?
Or even if they would let me borrow one to make a copy or take some measurements and have a look at the brackets so i could fabricate something to suit?
  • 1 month later...
Still looking for one, or a copy, or if some one will let me take pics of the setup with measurements.
PLEASE :)
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
