<a href="http://tinypic.com?ref=noynp2" target="_blank"><img src="http://i60.tinypic.com/noynp2.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Yeah dude how much for the ashtray?
Ash tray not for sale seperately, it's going with the gear surround and radio surround unless you have a buyer for those also
price drop
all door cards $600
headlights $900
c-west kit $1200
guage cluster $300
carpet $250 (has one tear behind drivers seat, about a 30mm)
Rear carbon diffuser with brackets $2000
rad support $100
HI DO YOU HAVE THE FRONT BAR REO OR THE BRACKETS THAT BOLT BETWEEN THE HEADLIGHTS TO SUIT THE GTR BUMPER IN DOING A FRONT END CONVERSION ON MY GTT
Guy above me has tourettes.
Could you please post pics of all door cards (front and rear) separately?
I would like to gauge condition before making an offer.
And yes people, that means I "bags" them
Hey man, still got the exhaust?
Is it titanium all the way through, or only the rear muffler? Thinking of modifying to suit my sedan.
That is... if you're willing to post to Perth.
Cheers
  • 4 months later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
