Hey guys, up for sale is my 2001 NM35 stag. 111,000kms
Bought over from Vic and needs a few things done. Unfortunatly, due to unforseen circumstances, I no longer have the time or $ to fix her up :(
Body and Interior are in very good condition - besides the one scrape you can see in the pic.
Recently replaced rocker covers, however since putting all back together she now runs a little rough. Ive probably just missed a vacuum line or something, im not sure. Drove beautifully beforehand and drove over here to Adelaide from Melbourne no dramas.
She does need some tyres and front shocks. Rear discs also need machining.
Didnt want to take for an I.D until all this was sorted, so that will need to be done also. All compliance plates etc are all on the car.
Perfect for someone that knows a bit about these cars and could fix her up cheaply :)
Im pretty firm but flick me an offer, I now just need her out of my driveway as im about to build a new house!
$5500
0434980676
Corey
Edited by corza91
https://www.sau.com.au/forums/topic/448718-2001-stagea-250t-rx-four-sa-5500/
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
