Hi everyone
I have an 1989 4 door R32 GTS-t fresh from Japan.
Unfortunately it is auto and im gettting annoyed at it already!
I have all the main parts necessary for the conversion (I think), including a new heavy duty Xtreme clutch kit, with thrust bearing.
I was wondering are there any important details that need to be looked after when changing to the manual box as the people helping me dont have a whole lot of knowledge with skylines.
Also, is there a spiggot bush or bearing in there, and is it necessary to change it?
I would like to replace it to be sure but am not exactly sure what im after.
Any help or suggestions would be appreciated :headspin:
Hi everyone
Hi Scott090
This isnt a hard jod but some things wont fit such as the spigget bush its the wrong one change it yes .also the standard manuel crossmember wont fit
or the auto one i did this conversion in my r32 2 door and had to use a s13 cross member it fitted perfect u also hve to run wires for ur reversing lights & netruel switch as well as bridge two wires near the fuse box that run from the old auto box so the car will start otherwise you'll turn the key and nothing will happen and you'll pull your hair out as i did can't think of what colour wires they are at the moment but i did a search here to find them and of course the yoke on the tail shaft is wrong as you prob already know but they are the same length installinf the pedal box is no big problem either but a lot easier if u pull drivers seat out installing clutch master cylinder is a bit fidilly as the bolts are hard to get at once in position ,line mounting points are all there all u need is original lines and bolts up well u shouldn't have many probs with it i dont think auto starter motor bolts straight up to
Cheers Peter
the only problem i had was getting the bitch of a gearbox in and out of the car.. mine is a GTS4 and the auto and manual crossmember was the same ( thanks god! ). any questions just email or message me..
Have fun! :thumbsup:
Thanks guys that should help me alot, especialy if i run into any of those problems.
I am still waiting for some time to machine my flywheel before it goes in, and also waiting for my friend (Mechanic) to clean his workshop so we have some room to work. Hopefully fairly soon
Cheers
I have now machined my flywheel and is ready to go in!
I was wondering if anyone knows the dimensions of the spiggot bush i will need, and where to get it?
If worse comes to worse i could get a mechanic at work to try and turn one on our lathe (not too keen on this idea though)
Also, are there part numbers for the pilot bushings.
your help is muchly appreciated
Hi scotty090
Any clutch place should have them in stock there the same for all the rb engines as far as i know just ask for one for a vl rb30e N/A if there not sure there the same its what im using
Cheers Peter
no they are no the same size!!! repeat they are not the same size.
that's the one we tried to fit but ended up drilling out the centre to make it bigger. when i got my clutch replaced the guy said it was fu**ked!
I would advise consulting nissan on parts. They have all the diagrams for all the parts that sit between the crank and the gearbox, and will be able to tell you which parts are different, and which parts you will need. Funnily enough theyre more than happy to help you sus out which parts you need.
JK
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
