Hey guys, just wondering if its possible to unplug the o2 sensors without causing damage to find out whether car runs fine without them in use to find out whether they are the cause of a surging problem while cruising on flat road at 100-110 km/h and slightly rough idle for 30-60 seconds before coming good. Dont want to go replacing them if theres a way to diagnose whether its them playing up or not first.
Running factory ecu by the way
https://www.sau.com.au/forums/topic/448749-unplugging-o2-sensors-on-r33gtr/
Thanks guys. Changing spark plugs this afternoon so if that doesn't solve the hesitation/surging problem I'll try unplugging the o2 sensors and take it for a run to eliminate them or get confirmation i need a new set if it runs fine without them in use. Otherwise next step will be afm's.
Another question... If timing was changed slightly to suit power fc and then factory ecu was put back in, could that have anything to do with it? I've been told it shouldn't but Im not so sure
Well there you go. Youd think the place who tuned the power fc would have suggested that after i rang them when it started playing up asking if that could be the issue or if it needed to be done but said no it should be fine :-/ better find someone with a timing light then !
Changed spark plugs first with iridiums and started fine and idled fine while cold. I let it idle till it was warm as it was getting to nearly 2/3 on the temp gauge it started to idle rough like it was last time I drove it. Also changed the fuel filter and hasn't it don't its job since it was last changed. The black shit that was coming out of it was unreal so good thing I decided to change it anyway. After that the idle was still rough so figured i'de try unplugging the o2 sensors one at a time. unplugged rear one first and waited 10 seconds and no change. unplugged the front one waited about 5 seconds and low and behold the idle corrected itself and was purring like a kitten again, plugged it back in and after about 5 seconds.... idling rough.
Now I haven't yet been able to take it for a drive on the open road to see if the surging has gone away with the o2 sensor unplugged at between 100-110km/h where it was playing up before but fingers crossed once I put new o2 sensor in, it'll solve that issue too as it started at the same time the rougher idle did.
Thanks for everyones help and suggestions
AFAIK, the ECU ignores the O2 sensor(s) at idle and on a cold engine, so I am perplexed that unplugguing either of the sensors made any difference.
You may well have fouled the plugs by letting the engine simply idle to warm up. Engine runs rich when cold, best to drive it to warm up the engine faster. The fouled plugs, particularly if they are Iridiums, could well be a contributor to your idling problems.
The surging may well be the ATTESSA complaining about worn rear tyres.
Well it definitely did make a difference so I recommend others try the same if the same symptoms ever occur. I may try to get a video tomorrow to show the difference.
As for the plugs, if you read above, we actually only put the new plugs in today and the ones that we took out weren't fouled anyway but I just put the new ones in since I paid for the iridiums.
Never knew the attessa system complained about rear tyres lol. Im pretty sure there is still plenty of tread, it happened when just cruising on a flat, straight road at 100-110km/h at +/- 3000rpm so I doubt there would be any traction loss. Will take it for a drive tomorrow to see if it still does it.
the factory narrowband o2 sensors are used for idle and cruise conditions (light load) no factory tune car i've ever seen will foul plugs just from letting it idle to warm up. you are talking about water temp fuel correction....the ecu will input more fuel when the engine is cold.
Ok so just went for a good drive to sit on 100/110km/h for a fair while and low and behold, it drove better and smoother than its ever driven! No hesitation, surging at all and actually feels like it has more power and better acceleration which may have something to do with the filthy fuel filter we replaced lol.
  • Like 1
I had the same problem. It does affect the idle and definitely affects low rev cruise quality and mostly acceleration. By acceleration I mean backing off or cruise then move the accelerator and there is a flat spot or hesitation. Accel-enrichment does not help. Disconnected the O2 and drives just like a factory car. I have since changed all cells at light load and cruise to 14:1 AFR and run without a O2 sensor. It is better on fuel consumption at 420-430k to a tank and drives beautifully.
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
