1st October...
* Move clocks forward this Sat
* Change 9v batteries on smoke detectors
* Check pollen and air cond filters
* Clean gutters this month and if near gum trees Dec too.
* Fertilise plants and WeednFeed lawns
* Get rid of leaf litter in fire prone areas.
* Not to mention that you'll be vigilant about your speed this weekend
https://www.sau.com.au/forums/topic/448785-tis-the-season/#findComment-7399935
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
