Testing Rb20 Coil. Car Suddenly Wouldnt Restart. Adding Lead To Coil To Connect Spark Plug
hi mates have a problem with my rb20 hilux that started this afternoon. I started it up and reversed out my driveway. car died when I put the clutch in to go from reverse to neutral (does this a lot when cold. usually restarts straight away. CAR HAS HALTECH E11v2 so prob cold start tune). today it didn't restart. cranked for ages trying to get it going but wouldn't go and battery got too flat.
I changed the spark plugs now so I know there good.
mainly what I want to know is how do I make a thing ive heard of before where you connect a spark plug lead to the coil pack then put spark plug into that like a common spark plug setup so I can look for spark to rule out spark issue. im not sure how to connect it onto the coil
thanks for now mates
I would say you have no fuel then either.
Do the usual, check fuses. Then i would pull cas out and turn by hand to see if the injectors click and I'd there is spark. Then you have to set the timing due to removing the cas.
What fuses should I look for? Since its an engine converted car the stuff is in different places and probably unmarked.
I get fuel pressure at the guage near the fuel rail so fuel pumps are going I believe. Dunno bout injectors.
Setting he timing is going to be shit I rekn. Apparently aftermarket ecus don't set the timing off the Induction loop thing? And I don't know what they have set it too. Or will it just be tdc in regards to setting cas timing?
Edited by joe blo
Like you said due to conversion what fuses do you check? If you don't k ow no way will I know.
The fact the pump is priming might mean the ecu Is turning on.
Fuel pumps wired to start with ignition is bad. Very bad in a crash. Should be controlled via the ecu.
Edited by Ben C34
Yea probs bad. I suspect that because they just run constantly once turn the key. Doesn't turn off when priming. Hopefully my ecu isn't dead. I don't believe the e11v2 has any lights on it so can't get quick idea if its getting power
I've done some more looking and thinking.
I hooked up spark plug to coil and prob have no spark.
Then removed spark plug and no fuel on it
I connected another cas I had (unconfirmed weather good or not tho) and turned it by hand with key in the on position. Nothing happened. No spark no injector noise.
My next thinking is I want to check power getting to the ecu and then follow from there. Problem is the haltech e11v2 doesn't have any lights in it to see if its powered up. Is there a way to check power to it?
It's a patch connector thing so the standard ecu plug is still there intact. I am now thinking of obtaining a standard rb20 ecu just to see if it lights up as my test for power getting to the ecu.
Any other ideas mates? Just bought house. Ment to be selling car. dream boats f**ked :(
did some more testing. didn't need standard ecu. I checked it with multimeter. has power.
what would be the next thing after the ecu I could check to make sure power is going out of the haltech ecu?
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
