Hi guys I currently have a standard bottem end 33 gtst
Mod list in
Pfc z32
Bosch 044
660cc injectors
Op6 highflow
Tuned at 250kw injectors currently hitting 64% duty
Question is do I have enough headroom for e85 with these injectors or do I need to go bigger also what else needs attention before I head down this path
https://www.sau.com.au/forums/topic/448809-e85-question/
That's abit broad. What is an early death? 2years? Thats mine Thus far and cars are still spot on.
Not sure if it was coincidence, but my primary feed pump got a bit lazy after I put the engine back together. It was sitting around for 10 months between when I popped the engine and got it back together. I only picked it up because the fuel pressure was falling and afr's were leaning out before the secondary feed pump came online. If you have a look for if, 500 working hours the 044's are rated at on E85 fuel.
https://www.sau.com.au/forums/topic/448809-e85-question/#findComment-7393304
Depends how much power you want, but I would say 660cc injectors won't get you far.
I'm using 875cc injectors and I'm at 92% duty cycle with a Hypergear SS2 turbo.
But if you're getting the E85 itch just drop in 1000cc injectors and a Walbro 450 E85 pump.
https://www.sau.com.au/forums/topic/448809-e85-question/#findComment-7393326
I imagine just being submerged in the fuel isn't the issue, the bronze bush bearings will fail after a while without the lubrication of the petrol. Stick to pumps designed for ethanol/methanol and you will be fine.
https://www.sau.com.au/forums/topic/448809-e85-question/#findComment-7393566
044 is not rated for E85 and will die an early death. Best not to take the risk and put an ethanol compatible pump on it on a "just coz" basis.
044 would have to be one of the most reliable pumps to use on E85.
040 on the other hand die left right and centre on e85
https://www.sau.com.au/forums/topic/448809-e85-question/#findComment-7393702
660 is definitely on the short end of the spectrum for that turbo on E85. It might restrict your boost to around 18psi. Hard to say
I use 1000cc injectors and 81% duty cycle with a 21U highflow 306rwkw. But my fuel pump isn't the best.
You could bump fuel pressure up perhaps. but I'd be looking into a set of top feeds
https://www.sau.com.au/forums/topic/448809-e85-question/#findComment-7393785
run a little e85 safe 2 stroke oil in with each tank to save your Bosch pumps.
This is the shizzle here https://www.motul.com/system/product_descriptions/technical_data_sheets/136/original/Micro%202T_GB.pdf?1290086772
https://www.sau.com.au/forums/topic/448809-e85-question/#findComment-7396142
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
