I have just put on some slick tyres on the front of my skyline, the tyres are kumho s700 245/645/R18.
On qtr lock the tyres grab the skirts, and rip them out
Based on the pics, the coilovers need to be raised, before I go about doing this, do you think it's going to fix the rubbing or am I wasting my time? Looks like a fairly significant ride height change is necessary.
Or is there something else I can do?
Thanks
https://www.sau.com.au/forums/topic/448819-slick-tyres-rubbing-on-skirts/
Wheels look to be a hell of a long way back in the arches. What sort of caster are you running?
Not too sure, it's been like that since I got the car, I thought it was unusual.
In terms of suspension the only thing aftermarket is coilovers and adjustable camber arms as I am aware....but I maybe wrong
What should I be looking for?
That last picture still makes me think that you need to wind on some more caster - the wheels are a long way back in the openings. You will need adjustable caster rods to be able to do it though.
On the actual tyre size issue - your tyres are too big. Standard size for an R32 is 205/55-16. Next most standard size is the GTR size, which is 225/50-16. Those are almost the same rolling diameter. The best matching bigger size is 235/45-17 (which is also the V-Spec size).
The standard rolling diameter is 632mm. The 235/45-17 size comes out to be 643mm, which is close enough to standard to be OK and also it's about the same size as the slicks advertised rolling diameter of 645mm. The Achilles 18s that you were running should have a rolling diameter of 669mm, which is far too large and not surprising that they rubbed.
So we have a problem. The way the current slicks sit looks like they are similar in size to the Achilles, which were too big......but the sizing of the slick shouldn't be too big.
Next question is.....what is the wheel offset? Looks kinda low. That won't help.
Like GTSBoy says you need to get some adjustable castor rods and wind on about 6 or 7 degrees. But that might not fix your problem. I got a set of slicks exactly the same size and type as yours and they are too big for my Stagea. I will have to go back to the 17s I had before. For comparison below is a pic of my car with 17in slicks and below that my previous Stagea with 16in semi-slicks (on GTR wheels):
I think the maths might have been slightly off...
235/35r18 should have a diameter of 622 mm
245/645/R18 has a diameter of 643 mm
I now have a 10.5 mm radius difference, hence the rubbing
So now with adjustable castor rods, any specific brand I should be looking at or go cheap on a pair?
When you say may not fix the problem, I am assuming even with xx degrees of castor I will never get full lock without rubbing?
Um......no problem with the maths. At no point in the thread prior to your post quoted above, had anyone, you or me, said anything about a tyre that was 235/35. You said 235/45-18 and I worked out the numbers on that.
The 245/645 slick has an advertised diameter of 645. It's in the number. No point quibbling over the difference between the 645 in its identifying number and the 643 that may be written on its actual spec sheet.
So. Caster rods. NEVER BUY CHEAP SUSPENSION COMPONENTS. Tein, Cusco, Nismo, etc etc are good. Hardrace are probably good. Any of the Hu-flug-dung brands should be viewed with suspicion.
And what is the offset on the wheels you are running?
+20 offset on the fronts,
Taking a closer look the wheel alignment is way out
GTSBoy nailed it.
Just looking at your pics, it looks like it needs a butt load more castor. When you get them to align it, just ask them to screw in everything they can.
I run 240/68/17 michie slicks on my 180. They scrub the inner guard on full lock, but don't scrub anywhere else. That's on a 17x8.5 +22.
I suspect castor will solve your issues.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
