I have just put on some slick tyres on the front of my skyline, the tyres are kumho s700 245/645/R18.
On qtr lock the tyres grab the skirts, and rip them out
Based on the pics, the coilovers need to be raised, before I go about doing this, do you think it's going to fix the rubbing or am I wasting my time? Looks like a fairly significant ride height change is necessary.
Or is there something else I can do?
Thanks
https://www.sau.com.au/forums/topic/448819-slick-tyres-rubbing-on-skirts/
Wheels look to be a hell of a long way back in the arches. What sort of caster are you running?
Not too sure, it's been like that since I got the car, I thought it was unusual.
In terms of suspension the only thing aftermarket is coilovers and adjustable camber arms as I am aware....but I maybe wrong
What should I be looking for?
That last picture still makes me think that you need to wind on some more caster - the wheels are a long way back in the openings. You will need adjustable caster rods to be able to do it though.
On the actual tyre size issue - your tyres are too big. Standard size for an R32 is 205/55-16. Next most standard size is the GTR size, which is 225/50-16. Those are almost the same rolling diameter. The best matching bigger size is 235/45-17 (which is also the V-Spec size).
The standard rolling diameter is 632mm. The 235/45-17 size comes out to be 643mm, which is close enough to standard to be OK and also it's about the same size as the slicks advertised rolling diameter of 645mm. The Achilles 18s that you were running should have a rolling diameter of 669mm, which is far too large and not surprising that they rubbed.
So we have a problem. The way the current slicks sit looks like they are similar in size to the Achilles, which were too big......but the sizing of the slick shouldn't be too big.
Next question is.....what is the wheel offset? Looks kinda low. That won't help.
Like GTSBoy says you need to get some adjustable castor rods and wind on about 6 or 7 degrees. But that might not fix your problem. I got a set of slicks exactly the same size and type as yours and they are too big for my Stagea. I will have to go back to the 17s I had before. For comparison below is a pic of my car with 17in slicks and below that my previous Stagea with 16in semi-slicks (on GTR wheels):
I think the maths might have been slightly off...
235/35r18 should have a diameter of 622 mm
245/645/R18 has a diameter of 643 mm
I now have a 10.5 mm radius difference, hence the rubbing
So now with adjustable castor rods, any specific brand I should be looking at or go cheap on a pair?
When you say may not fix the problem, I am assuming even with xx degrees of castor I will never get full lock without rubbing?
Um......no problem with the maths. At no point in the thread prior to your post quoted above, had anyone, you or me, said anything about a tyre that was 235/35. You said 235/45-18 and I worked out the numbers on that.
The 245/645 slick has an advertised diameter of 645. It's in the number. No point quibbling over the difference between the 645 in its identifying number and the 643 that may be written on its actual spec sheet.
So. Caster rods. NEVER BUY CHEAP SUSPENSION COMPONENTS. Tein, Cusco, Nismo, etc etc are good. Hardrace are probably good. Any of the Hu-flug-dung brands should be viewed with suspicion.
And what is the offset on the wheels you are running?
+20 offset on the fronts,
Taking a closer look the wheel alignment is way out
GTSBoy nailed it.
Just looking at your pics, it looks like it needs a butt load more castor. When you get them to align it, just ask them to screw in everything they can.
I run 240/68/17 michie slicks on my 180. They scrub the inner guard on full lock, but don't scrub anywhere else. That's on a 17x8.5 +22.
I suspect castor will solve your issues.
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
