1996 180SX Type X 167xxxkms, Rego till 25th of May 2015
$13,000 Negotiable or will swap for a R34 or R32 with RB25
0447 088 511
Car had a little tap at wakefield it is the last picture in the post, panel beater came and looked at it said rad support just needs straightening and lining up of the panels and good to go.
I have receipts for all work which was done by JEM and by my very close friend at his workshop. Car is merticulously maintained it is VERY clean inside and out no cracks in dash clean carpet seats etc. All Exterior and Suspension work was done less than 1 year ago
Modifications listed below have receipts for engine rebuild and engine work, i may have missed some little things but will try to add more as the days go on.
Located Sydney South West.
Exterior
-Resprayed Lexus Pearl White Less than 6 Months Ago
-Full Type X Kit
-Rocket Dancer Duck Tail Wing
-180SX Type X Front Lip
-Genuine Weather Shields
-BYO Wheels or can give you pair of URAS NS-01 and pair of Rota Grids
-Pumped Guards all round.
-Ichigo Bleach Anime Hood Vinyl (Will be removed upon sale)
-Project Kic's R40 Nuts
-Projector Style Headlights
-Sleepy Eye Controller
Engine/Drivertrain
-Rebuilt (stamdard) SR20DET at JEM 250KW At The Wheels With Dyno Sheets
-S14 5 Speed Gearbox
-Exedy 5 Puck Clutch
-Shimmed Diff
-GKtech short shifter
-Shifter Extention (Feels Awesome With Short Shifter)
-Garrett 3076R with Anti Surge Cover
-GKtech High Flow Fan
-6 Boost High Mount Manifold
-Custom 4" Intake Piping
-44m Tial External Wastegate Vent To Atmosphere
-All Braided Lines
-256in/264ex 11.5 lift Tomei Cams
-Greddy Cam Gears
-Tomei Rocker Arm Stoppers
-Walbro Fuel Pump
-Power Enterprise 850cc Injectors
-HDI Intercooler
-3" Exhaust with A Spec Blast Pipes
-3" Cat
-4" Custom Bellmouth Dump Pipe
-Cometic MLS Headgasket
-Greddy Profec Bspec 2 EBC
-Greddy Oil Catch Can
-Haltech E8 ECU With 3 Bar Map Sensor
-Re-Routed Main Harness Into Engine Bay
Suspension & Handling
-BC BR Coilovers
-Cusco Rear Strut Brace
-SPL Rear Toe, Camber & Traction Arms
-Rear Whiteline Sway Bar
-Front Megan Racing Sway Bar
-Full 5 Stud Conversion
-R34 GTT 310mm Calipers + Rotors Up Front
-GKtech ABS Delete kit
Interior
-Brant Alarm With Pin Code Start
-S15 Seats
-Greddy Gauges, Oil Pressure, Water Temp, Boost
-Grex Gearknob
-USB/AUX Headunit
-Alpine 6.5" Splits with Tweeters
-New Hertz Rear Speakers
-Mono Block Amp
-12" Alpine Type S Subwoofer
10688288_10152359978098575_7201861024669
10258625_10152091914288575_5807812292343
10256785_10152091914483575_3842268629503
1656437_10152091915753575_21586400209384
10291055_10152091914123575_7121212355736
1907983_10152091914418575_91033299184135
10277020_10152091914313575_6136312058610
10257467_10152091914473575_6139817183892
10173595_10152091914353575_2791507914935
1014479_10152091914263575_60535962868524
10171689_10152091915803575_8667469428238
