I have an R32 with Rb20det and recently it has started making a ticking sound coming from the the area around the alternator, number 5,6 injectors and waterpump ( I can't accurately determine where exactly the sound comes from but it comes from somewhere in this area. I took it to a mechanic who said it might be the lifters so I changed the oil (using new filter and flush) and it made no difference (the oil before could have been 10,000km old or more [bought it off someone who had no f**king clue]) it's gotten considerably louder since I took it to the mechanic and my mechanic is away till the end of this week, and i'm worried now that it might not last till he gets back.
What in this area makes a really loud ticking sound? It sounds louder than injector tick and sounds like external to the block (like it doesn't sound like it muffled from coming from inside the head/block) the car has also been recently pulled apart for a headgasket replacement with cometic gasket and ARP studs, while that was happening it got it's waterpump replaced. My main suspects for the sound are the waterpump/clutch fan. but yeah I have no way of knowing till next week when my mechanic gets back. does anybody have any clues? is this a common issue on RB's?
https://www.sau.com.au/forums/topic/448865-unusual-ticking-sound/
Um.......#5&6 injectors are at the opposite end of the engine to the water pump and alternator.
Why don't you do what is normally recommended in this sort of thread, and get a piece of hose, use it as a stethoscope, and listen around to find where the sound actually comes from?
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
