Hi to all
I am new but have been reading for years.. 3...4 i think
i want a skyline GT-R so bad but I am building a house, but i did add a 3rd garage
i got a idea that’s been bugging me for a long time, is that i use google to find the post i wana read because i find it hateful using the forum tabs and nothing is organised
can’t it be easy and have 5 tabs click on what series you have and then shows all your subcategories
example:
main forum page
R31
R32
R33
R34
R35
Then once you click on your tab you get all you subs like mods, DIY, brakes, suspension.... like what we have now
but would be nice to have a pre-subcategory main forum page.
for idea of what I’m talking about look at: http://www.pradopoint.com/ see how they got 90, 120 and 150 it really nice and yes i do have a 150 series Prado that’s why i know about that site
tell me what you think and maybe if we all put in our 2c we might get a change i hope :)
https://www.sau.com.au/forums/topic/448870-idea-forum-set-up-make-it-easy/
We've spoken before about this but didnt move on it because R32, R33 and R34 are quite similar in their chassis and systems. Ie, questions regarding the RB26, ATESSA or HICAS could be answered by anybody.
That said though, I'm really keen to redo the automotive categories as I think they are a little all over the place at the moment. We need to encourage the use of tags when people add new threads because that makes it much easier to find what you're looking for.
I like the idea of tags I did use all ten tags allowable to make this post.
But forced tags would help alot.
As for cleaning the forum up we just goto look at other forums for ideas have a look at the hyundai i30 forum I enjoy their site but the search bar is not the best but i hardly ever use it because its organized and yes I have i30 shitbox for driving to and from work only.
I did kinda forgot about how similar they are would cause bit of confusion. ...
Hear is link if anyone interested in having a look: http://www.i30ownersclub.com/forum/index.php?action=forum
Also what about spell check..?? Not like I need it but some might
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
