hi i really want my rb20det to go harder. it comes onto boost at around 4500. i would like it to be quicker. it is semi stock, running a different coil pack, i think new injectors and maybe a different pump. i was told to get a boost controller to boost it up. its running 12psi at the moment, what would you recommend running on a stock turbo. just out of interest what would be a cheap bolt on turbo upgrade that i wont need to muck around with. im on a 1st year apprentice budget so it isn't much.
https://www.sau.com.au/forums/topic/448895-rb20-more-power/
I would check it is a stock turbo and if it is check your cooler pipes, mine runs a 25 turbo and has full boost by 3200 max. Standard injectors are red so you can see if they are different, as far as power up on a budget 25turbo, front mount cooler 3inch cat back, remove mufflers depending on quality and 14 to 17psi.
https://www.sau.com.au/forums/topic/448895-rb20-more-power/#findComment-7394716
seem like you have a r33/r34 turbo, high flow or you have some things to chase like checking for boost leaks, base timming off, bad cat
as for lag shorten intercooler piping, add adjustable cam gears, use an adjustable waste gate so u can preload the force on the actuator for more response or use an EBC
https://www.sau.com.au/forums/topic/448895-rb20-more-power/#findComment-7394765
The only sane option here (and by far the most economical) is to take out the RB20 and put in a RB25.
Even a stock RB25DET with a basic Toshi Remapped ECU will run rings around a RB20DET with an aftermarket ECU, high flowed turbo, injectors and all that.
Do the maths, simple.
I've owned a RB20DET in the past, spent money to make it fast.. ended up selling the car because it was a lost cause.
https://www.sau.com.au/forums/topic/448895-rb20-more-power/#findComment-7394967
I'm in a similar boat. Pun intended.
Your next step is a retune with a z32 afm, upgrade injectors if they're stock and a bigger turbo like a hyper gear or gcg high flow
Check out the other subsections of the forum for more info.
forced induction> rb20 dyno results
https://www.sau.com.au/forums/topic/448895-rb20-more-power/#findComment-7395292
I think people are missing some rather tasty RB20 turbo combinations out there by not thinking outside the box. Personally, if I had an RB20 and I wanted good mid range and grunt I would go one of these , depending on whether you wanted a tad more power or a tad more response. If you can run E85 and bump boost from 18-19psi to 22-23 psi then you would think it would be a bloody good setup for reasonabel dollars.
Take one of these
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-TD05H-T517Z-T518Z-T3-8cm-AR61-V-Band-External-Gated-/281436442957?pt=AU_Car_Parts_Accessories&hash=item4186eb514d
Weld a Turbsomart 40m external gate to it and then grab one of these to slap in the housing and work on your std exhaust manifold.
http://www.bptstore.com/Subaru-WRXSTi-TD05H-16G-XT-Turbocharger_p_23.html
OR
http://www.bptstore.com/Subaru-WRXSTi-TD05H-18G-XT_p_11.html
With std inlet manifold, setup cam gears I think you would have a good setup with the durability of the RB20 that pulls some healthy revs and make better power response wise then the horrible hi-flows that are available for RB20s that dont seem to ever match the response of the my 20G setup and certainly no hope in hell of making the 310rwkws the 20G made
Rememebr that std RB20s have pretty durable pistons and bloody strong rods and with such a short stroke the piston speeds and bottom end loads can handle a fair wach of boost safely. E85 gives you a nice safety blanket but a quality tune on 98, ideally United 100 will give you pretty damn good results IMO
Turbo, housing and gate with modded dump etc woudl be 2k. Relatively straight forward installation and then just tune it up with Nistune, Z32 and some injectors. All up depending on what you do yourself and what you have to pay to get done you could have it all in and done for 4k ish. Frankly I wouldnt worry too much about the RB25 turbo upgrade...better off workign towards a better turbo setup as the CU and tuning is going to cost the bulk of the coin so may as well save until you can club it with a good turbo
https://www.sau.com.au/forums/topic/448895-rb20-more-power/#findComment-7395971
what should i be looking for to see if its a stock turbo? would anyone recommend an rb25 turbo. is it a bolt on upgrade and what mods would i have to do to support a new turbo. if it is already an upgraded turbo, how can i get it to spool quicker and come on boost better. im trying to get the car ready for powercruise. also do i need to change the exhaust for a rb25 turbo because i have a screamer pipe i would like to keep. i will try to get a photo tomorrow to see what everybody thinks it is. the skyline is my first fast import so only new to this
https://www.sau.com.au/forums/topic/448895-rb20-more-power/#findComment-7396034
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
