bbenny Posted July 1, 2004 Share Posted July 1, 2004 well i got out and had a blast last night at WSID. it was my first time ever down the quarter and it was awesome. i was a little dissapointed with my times, i just couldnt hook up a good 60ft time. so next time i will be running some better shoes i think. this time i was running the std 16" wheels with 205 continental crap tyres at 20psi it was good to see a bunch of forum guys out there too, thanks for all the advice too! my best pass was 13.5 ET 2.3 60ft 110mph what do you guys think would be possible if i could get a better 60ft? Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/ Share on other sites More sharing options...
OREX Posted July 1, 2004 Share Posted July 1, 2004 i should think that with such a high top speed thru the traps if you had grip i'm sure a high 12 will be possible. other guys out there have run a string of consistant high 12's with that terminal speed, so you might need better grip - different wheel/tyre combo maybe. Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-916551 Share on other sites More sharing options...
Cubes Posted July 1, 2004 Share Posted July 1, 2004 Thats a pretty decent ET. If you want decent grip and cheap get your self a set of 225 16" Simex's. They have a soft sidewall. Nice burnout and they get very sticky. Hows your diff? its not openwheeling even slightly? Its worth around $350 to get them shimmed up nice and tight from a diff specialist. Just exploring a couple options to help improve your 60ft. I forget what your mods are? Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-916619 Share on other sites More sharing options...
benm Posted July 1, 2004 Share Posted July 1, 2004 With a sub 2sec 60ft time and 110mph TS you have a solid 12.7 begging Don't forget to read my signature Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-916641 Share on other sites More sharing options...
Roy Posted July 1, 2004 Share Posted July 1, 2004 Thats a good trap speed, which tells me more about the performance of a cae between 60-200km/hr which is what im personally more concerned about rather then traction out of the gate . Hows your diff? its not openwheeling even slightly? Its worth around $350 to get them shimmed up nice and tight from a diff specialist. Wouldnt know the names of any places? Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-916733 Share on other sites More sharing options...
bbenny Posted July 1, 2004 Author Share Posted July 1, 2004 joel, my diff is in nee of a service desperately, its nothing like when i first got the car, also my left rear shock that i borrowed was blown, i noticed when i got there it was pissing out oil, and worked like a pogo-stick most of the time. so maybe diff and suspension would make a difference. im also interested in the simex's tyres, tell me more i did notice that one of the guys i ran against ran a 12.2 ET and he had the same 110mph through the traps as me, but is 60ft was like 1.7 Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-916751 Share on other sites More sharing options...
Cubes Posted July 1, 2004 Share Posted July 1, 2004 I wouldn't know of any places in Sydney. Most good diff specialists 'should' no how to re-shimm a diff. JMS also do it. When my diff was good it used to make the front end of the car feel like it was launching in to the air in first gear. Not so any more.. I drove a friends S15 that had mild mods, exhaust, fmic and 1bar of boost. It made me realise how stuffed my diff actually is. In the wet my diff tends to open wheel quite a bit. Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-916799 Share on other sites More sharing options...
MM2death Posted July 1, 2004 Share Posted July 1, 2004 Good work bbenny. Nice terminal speed! Scott Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-916868 Share on other sites More sharing options...
2rismo Posted July 2, 2004 Share Posted July 2, 2004 High 12 on street tyres Low 12 on slicks Adrian Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917102 Share on other sites More sharing options...
whatsisname Posted July 2, 2004 Share Posted July 2, 2004 Let me have a go for you Benny, I'll get you back up into the 14's @ 110mph no prob's Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917280 Share on other sites More sharing options...
bbenny Posted July 2, 2004 Author Share Posted July 2, 2004 yeha i need some tyres, what size were your nittos adrian? was it you with them mounted on std R32 wheels? who knows the cheapest place in syd to get nittos? ive got the bug now... so next time ill have some decent tyres and i think i will run less than 50L of fuel like i managed on wed ...idiot Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917610 Share on other sites More sharing options...
2rismo Posted July 2, 2004 Share Posted July 2, 2004 what size were your nittos adrian? 275/40/17 was it you with them mounted on std R32 wheels? No. There is another Skyline in Aus, probably more, that run 255/45/16's on std 33 gts-t rims although the more common approach is to run this size on R32 GTR rims. who knows the cheapest place in syd to get nittos? Come to the SAU BFGoodrich Drag Day on the 11th of August and try some BFG Comp T/A drag radials. A lot of development has gone into them and they're performing easily as good if not better than Nitto's. Brett has organised with BF to have 3 pairs of tyres to share and he's bringing his 3 pairs of 16x8" rims. Club members will have a chance to try these awesome tyres out and then buy new ones at a discounted price. Details in the Drag section. Adrian Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917638 Share on other sites More sharing options...
whatsisname Posted July 2, 2004 Share Posted July 2, 2004 I always run a full tank of juice, as I figure the extra fuel is offset by the traction advantage of more weight bias over the rear end. Where is the cheapest place to get Nittos anywhere!? Apart from the US. Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917644 Share on other sites More sharing options...
whatsisname Posted July 2, 2004 Share Posted July 2, 2004 Damn it BFGoodrich! Why don't you make a 275-285/40/17 I want something to run on my everyday rims (17 x 9). Currently it's either Nittos, or circuit spec semi-comps. I'd love to see a group drag radial purchase from the US. 2-3k worth between a few of us should make it worth while. I have a mate who has just returned from 3yrs in the US and he has contacts that could organise a shipping container with heaps of Nittos and the like. Food for thought. Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917660 Share on other sites More sharing options...
2rismo Posted July 2, 2004 Share Posted July 2, 2004 Did you not see the group buy/club offer on BFG? Adrian Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917706 Share on other sites More sharing options...
jnr32r Posted July 2, 2004 Share Posted July 2, 2004 Hey Ben, well done dude !! I know you were expecting better, but dont worry the times will come as soon as you are sorted. A couple of points tho, in your last run you didnt do a burnout which might have helped your tyres get a bit more grip. And on take off it looked like you got no wheel spin at all, it looked like the car had to rev from low which might have costed some time. In my car im pretty sure that getting a bit of wheelspin on launch will give a better run than say riding the clutch..... Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917713 Share on other sites More sharing options...
whatsisname Posted July 2, 2004 Share Posted July 2, 2004 Did you not see the group buy/club offer on BFG? Adrian No. Linkage please! Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917737 Share on other sites More sharing options...
2rismo Posted July 2, 2004 Share Posted July 2, 2004 Details in the NSW Events Section I think. Really a day for SAUNSW members to try out the tyres but we can prob arrange for the price to be extended to other forum users. Adrian Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917982 Share on other sites More sharing options...
Roy Posted July 2, 2004 Share Posted July 2, 2004 I had a look at the thread, didnt see any reference to price? What are 255/16s worth... and your thoghts over any time advantage over D01Js, if its only 0.2sec i wont bother, but its if its likely to be over 0.5sec then will be worthwhile.... Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917995 Share on other sites More sharing options...
2rismo Posted July 3, 2004 Share Posted July 3, 2004 rrp on 255/45/16's is about $430.00 We should be able to save a fair whack on that price but we'll have to see. For drag racing, proper drag radials make a WORLD of difference. From Falken ZIEX ZE-326's (12.5sec) to Nitto NT555R's 11.9 secs. All about the first 60 feet dude. The rest is relatively simple. Come to the drag day and try them out. That way you'll be able to decide whether they make a big difference to your times or not and if you're happy, buy a pair. Adrian Adrian Link to comment https://www.sau.com.au/forums/topic/44893-first-time-down-the-quarter-last-night/#findComment-917999 Share on other sites More sharing options...
