R33 GTS-t
Imported and complied in 07 in 100% stock form except stereo.
320kw at 17psi.
Gt35R turbo
XTR australian made highmount manifold
Custom plenum + Gizzmo phonelic thermal gasket plate
Q45 90mm throttle body
46mm external gate
740cc injectors
Z32 AFM
Splitfire coilpacks
Catch can
Header tank
Power FC
Shift-i 7 stage LED shift light 600mm FMIC - custom piping with twin GTR bov's
Exceedy clutch -HHHD
Shimmed diff - 3mm preload
G4 356mm 8 pot brakes front
OEM rear calipers with slotted rotors and QFM pads
Bilstein shocks/coilovers 8kg springs front - 5kg rear
Whiteline sway bars- 24mm adjustable front, 22mm adjustable rear
GTR strut braces front and rear Subframe lock bushes
Custom Brad Sherriff modified front LCA's - motorsports rose joints.
Adjustable castor/tension rods. Adjustable front UCA's.
Adjustable rear UCA's.
Hicas lock bar.
Sparco pro 2000 seats with Sparco kidney pads on Bride rails.
Sparco 4 point harnesses.
Bond Roll Cage.
Quell fire extinguisher
Scratch resistant Lexen screens in doors and rear.
Lightened doors.
Completely stripped interior and floor pan and interior painted out to match exterior. Roof lining and door trims still fitted
Momo steering wheel, detachable hub/wheel.
Custom front bar/splitter
400r side skirts
Veilside rear bar with custom diffuser
MU Secret carbon bonnet
Carbon headlight intake
Japspeed rear wing, fully adjustable plus boot lid bracing. 18×9.5 +25 DTM wheels all round with brand new kuhmo semi slicks - V70a mediums. Never fitted
new gates timing belt plus idler and tensioner bearings plus new bolt and stud fitted and water pump in last 500 kays
Rear guards rolled and lipped
front guards pumped (aprox 2") Panel and paint in excellent order. Plus mocal oil cooler kit - needs fitting. Tuned By pro automotive and ran on castrol edge 10w60 since 07. Never missed a beat doesnt use oil good safe tune, and did 50 thousand kays in its current form and a handful of social track days. Cars had quite a lot of weigh removed around 180kg over a standard R33.
Cage is CAMS legal for state level motorsport, needs to be log booked.
No test drives. And needs wheel alignment. 186000 kays. I have put 70000 on it. Only thing I have ever replaced that wasnt by choice was new drivers side window regulator. Still has electric windows.
Offers over 10k. Located in Tas. [email protected]
Edited by Mr. Untouchable
  • Like 2
https://www.sau.com.au/forums/topic/448939-r33-gtst-sooty-for-sale/
have had two emails about people wanting to buy the front bar, yes you can have it, 9 grand, comes with a r33 attached to it.
  • Like 1
  • 3 weeks later...
