I bought a new set of BC coilovers (the red ones not gold ones) and i was wondering if it is worth it taking it to a suspension place so they can full adjust the springs and dampers for the best nice, low and comfortable ride. Is it worth the price? pedders charge too much, like $140 and other places like big o tyres only $50. Or should i do them myself? ride now it seems ok, i just really adjusted the dampers to soft but it can be better. Any help, advice and tips would be appreciated. thanks
https://www.sau.com.au/forums/topic/448953-optimum-settings-for-new-coilovers/
No. Fit them and adjust the dampers to suit your style. If they are too hard then you should have bought them with lower spring rates or gone for replacement shocks and springs for the stock setup
i know i was thinking i should of payed $100 extra and got the gold ones with that extra canister on the side.
When i was adjusting the coilovers i was measuring them up with my older ones ... do i adjust the bottom bit of the coilver or do i adjust the spring for height? i cant really remember what i did...also the button on top of the coilver soft damper = bouncy ride and hard damper = stiff ride? I JUST WANT BEST COMFORTABLE RIDE WITH LOW HEIGHT! its a r32 gtst by the way :bunny:
Adjust the bottom one. Don't adjust the locks around the spring.
Install them, get your ride height right and then play with dampers. I cant tell you damper setting 12 will be fine because what works for one person doesn't work for another. YOU know how you like your car to feel. Not me
i actually adjusted most of it with the bottom part but when i was lining it up to the right mm i did the spring too a bit too...what does it do? sorry im not 100% sure what the adjusters on the coilovers too..i just want the exact same settings on all the coilovers
Edited by IM-32-FK
It changes the spring rate basically. but if you loosen it to get lower spring rates then you run the risk of the spring falling out of the holders.
If it were me I would just measure all the spring heights and adjust the one you changed to be the same height. You will need to use something accurate like vernier calipers (if you have any/any big enough)
Then loosen the bottom one and spin the base to lower or raise the height. I put mine in the car and then adjusted them to suit the height I wanted. Measure the exposed thread, then adjusted the other side to be the same
The more you lower, the more adjustability you will have to add via adjustable bushes or arms to be able to get a decent alignment. The lowest you can go it about 350mm front 340mm rear (wheel centerline to guard) before the handling just becomes horrid. At that height you need to add quite a lot of adjustable components. If you can find the old SydneyKid group buy threads the info is in there.
Low and comfortable trade off each other, so you generally don't expect to get both.
Re dampener setting: set it half way then drive it for a while. After your used to it, then play with it for a bit.
so basically keep the stock spring height, just adjust the bottom bit of the coilover and the button on top for the dampers? damn, im not sure what the stock spring height was.
The spring adjustment is to adjust preload, BC will have a recomended pre load to start of with and for most people they will keep at that if you aren't fine tuning,. Eitherway its always good to check that preloads are set correct on all new coilovers before just chucking them in sometimes they are off.
Aren't BC dyno'd before they're shipped? If so, I'd leave it at the settings, maybe move it a little bit either way.
i adjusted the spring, i had to raise it a bit. Isnt that how u are supposed to change the height? move the spring up and down? i moved up the spring because it was sagging to the days. Someone told me here to change the adjustment at the bottom where the single bolt sits, but people at tyre shops told me to adjust the spring, so i took their word. Its sitting on r32 gtr stockies which is 225/50/16 and there is maybe half an inch gap between the arch and the wheels. Whats to point of buying coilovers if you are gonna leave it on stock settings?
seriously, i think i f**ked up, because the ride still isnt smooth, you can still feel it pretty hard going over potholes. The dampers are on softest setting too. Oh and parramatta rd too...it was a nightmare especially between parramatta and auburn
Edited by IM-32-FK
they are coilovers, they are not soft.
bcs run i think around 8k which is double your stock spring rate. they are going to be hard because they are 8k coilovers, if they are not suited to how you like the feel possibly consider selling and buying the sydneykid setup.
the car still wobbles left to right when you go over those dodgy potholes, crevises, incles and declines etc...u know what i mean? i still believe they can run better i just need to know the right answer. Im gonna try to increase the dampers to hard and change my tires as i need to anyway. Also i want to know the best spring lengths and the length of the adjuster at the bottom. In time i guess
Edited by IM-32-FK
There are 2 adjustements on the spring. One is for adjusting height. One is for adjusting preload. They are not meant for adjusting the opposite thing.
You can either play with them and work it out for yourself (should take about 30 seconds) or you can google what the spring adjustments on a coilover are supposed to do.
^ This guy knows. I'd like a ride in your car one day.
Try increasing the dampers (i.e. making them a bit harder). Your springs are pretty stiff, and probably not that well dampened (considering the cheap dampers), expect a stiff ride.
I paid people at tyre shops to align my wheels, and my car drove worse afterwards. They also said that <insert tyre they are trying to sell> is better than what I have on my car, no, it's not. They also said that I couldn't fit 265/35/18 (on BNR34 wheels) on my car, psh. I would laugh at their faces if they told me to adjust the suspension height with the spring seat when I have base height adjustable struts.
I used to drive through Parramatta Rd on almost a daily basis with my GT-R. I had old TEINs on there, my gods it was horrid. At least the Ohlins installed now are more compliant (although not 'tuned').
FYI standard R32 GT-R spring rates are (from memory) 3 and 3.5 kg/mm (f,r).
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
