I just removed the old Nolathane branded arms due to the bushes getting tired and went through the same realisation that new bushes vs new arms pushed things in favour of new arms. I bought the Hardrace rubber ones just like you have.
If you wind on too much castor you risk fouling the tyre on the plastic guard up front so you can cable tie it forward or even better remove the lower screws holding the plastic guard and drag it forward and re-secure it forward.
Wind on max lock and see if the tyre is scrubbing, if it isn't there is more adjustment available, you should be able to wind more on.
Ah, I see what you mean. No, my tires aren't rubbing on the plastic. Though for some reason, the arms are at their maximum adjustment. Something not quite right here, if you say you can get more than ~4.45 degrees with the same arms.
Do you have a 4WD or 2WD? What camber arems (if any) do you have? I have these:
$T2eC16ZHJGkE9no8iLlRBQGeFHm-tQ~~60_57.J
...they're fairly common I believe... and they are at maximum adjustment as well, and still I have -1.15 degrees camber at the front.
Maximum adjustment for the castor rods means they're wound in as short as they will go. Maximum adjustment for the camber arms means they're wound out as far as they will go. Not sure what's going on, since the car is not overly low (on standard diameter tyres, I can fit two & 1/2 fingers between the tyres and guards - I measure ~355mm wheel centre to guard).
If I can't get more caster with adjustable arms, then I'm stumped.
Something that sticks in my mind though is that when I was measuring up the arms to replace the stock ones, and I had them side-by-side, I'm sure the stock bolt locations required several turns on the hardrace arms to wind it out to make up the length. But I have felt the adjustment on the car, and it seems the passenger side is as short as it will go. Grr.
No worries :) I haven't actually confirmed it with anyone, that was just my interpretation of the front suspension geometry based on year 10 metal work (pedal prix) lol. I checked the arms on the car, and there are perhas 1 or 2 threads visible on the driver side and maybe 2 or 3 visible on the passenger side? (the reason these weren't used, I guess, is because the arms would need to be removed to achieve the final adjustment, since one end of the adjustable section has run out of thread).
It would be worth your while to undo the arms and turn them to make all the thread disappear. Don't know how much that would give you but if that's not enough... time to take to the turnbuckle with a hacksaw (unless you can find some thinner lock nuts)!
Great idea, I should have thought of that. I should be able to find some shorter lock nuts because they're quite long; if the ends have enough thread I might also cut some off. Cheers :)
PS I suspect the threaded rod is attached to the turnbuckle. But if not, then I'll just look at trimming the turnbuckle.
Edited by DaveB
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
