I just removed the old Nolathane branded arms due to the bushes getting tired and went through the same realisation that new bushes vs new arms pushed things in favour of new arms. I bought the Hardrace rubber ones just like you have.
If you wind on too much castor you risk fouling the tyre on the plastic guard up front so you can cable tie it forward or even better remove the lower screws holding the plastic guard and drag it forward and re-secure it forward.
Wind on max lock and see if the tyre is scrubbing, if it isn't there is more adjustment available, you should be able to wind more on.
Ah, I see what you mean. No, my tires aren't rubbing on the plastic. Though for some reason, the arms are at their maximum adjustment. Something not quite right here, if you say you can get more than ~4.45 degrees with the same arms.
Do you have a 4WD or 2WD? What camber arems (if any) do you have? I have these:
$T2eC16ZHJGkE9no8iLlRBQGeFHm-tQ~~60_57.J
...they're fairly common I believe... and they are at maximum adjustment as well, and still I have -1.15 degrees camber at the front.
Maximum adjustment for the castor rods means they're wound in as short as they will go. Maximum adjustment for the camber arms means they're wound out as far as they will go. Not sure what's going on, since the car is not overly low (on standard diameter tyres, I can fit two & 1/2 fingers between the tyres and guards - I measure ~355mm wheel centre to guard).
If I can't get more caster with adjustable arms, then I'm stumped.
Something that sticks in my mind though is that when I was measuring up the arms to replace the stock ones, and I had them side-by-side, I'm sure the stock bolt locations required several turns on the hardrace arms to wind it out to make up the length. But I have felt the adjustment on the car, and it seems the passenger side is as short as it will go. Grr.
No worries :) I haven't actually confirmed it with anyone, that was just my interpretation of the front suspension geometry based on year 10 metal work (pedal prix) lol. I checked the arms on the car, and there are perhas 1 or 2 threads visible on the driver side and maybe 2 or 3 visible on the passenger side? (the reason these weren't used, I guess, is because the arms would need to be removed to achieve the final adjustment, since one end of the adjustable section has run out of thread).
It would be worth your while to undo the arms and turn them to make all the thread disappear. Don't know how much that would give you but if that's not enough... time to take to the turnbuckle with a hacksaw (unless you can find some thinner lock nuts)!
Great idea, I should have thought of that. I should be able to find some shorter lock nuts because they're quite long; if the ends have enough thread I might also cut some off. Cheers :)
PS I suspect the threaded rod is attached to the turnbuckle. But if not, then I'll just look at trimming the turnbuckle.
Edited by DaveB
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
