Yes i believe the head shield will need to be removed. There is a special tool to remove the o2 sensor, but you can probably do it if you have some good tools, its just in hard to reach spot. Im not sure about all the bolts for the front pipe
Thanks for the help, had a few grief moments on the way, but luckily I had a can of SP7 around!
For anyone else thinking of doing this, do it! Save your money on labour and spend it on other stuff.
The O2 sensor on the dump, and the other sensor on the cat dont require a special tool, a spanner will do the trick. The one on the cat is not that too hard to get out, but the 6 screws on the dump and the sensor on the dump are real bastards. I found the best was the remove the sensor on the dump was to get a spanner and do it from the engine bay, here you have the most leverage room, but it isnt much!
Taking the heat sheild was just a matter of unscrewing all the screws, and noticing there was a ground wire there, so unscrew that and remember to put it back.
However the two screws that plug into the turbo seal are impossible to screw back in with the new dump, Iam running at the moment for only for screws in, you reckon it will cause a big problem? I'll try and and get some shorter screws.
Would having no heatshield be bad for the components around the turbo? Iam worried about the plumbing around there, is the best way to protect them is to buy that heatwrap stuff?
If your a novice like me, it took me about all day to install.
:wassup:
Cheers.
  • 3 weeks later...
The heatshield will not fit, there is no where to bolt it on and the dimensions are too small.
I havent put thermal wrapping on it yet (where to get some?), most of the electrical connections and hoses are quite protected already, but its best to be safe and spend the little then to see a rubber hose melted into funny shapes.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
