hairdryer33 Posted September 23, 2014 Share Posted September 23, 2014 I have a s1.5 33 just wondering why there is a second plug on the tps? Ive seen some with the ssme set up and others with a single tps plug provision. Link to comment https://www.sau.com.au/forums/topic/448973-tps-twin-plug/ Share on other sites More sharing options...
Ben C34 Posted September 23, 2014 Share Posted September 23, 2014 I have a s1.5 33 just wondering why there is a second plug on the tps? Ive seen some with the ssme set up and others with a single tps plug provision. For an auto trans. Link to comment https://www.sau.com.au/forums/topic/448973-tps-twin-plug/#findComment-7395638 Share on other sites More sharing options...
hairdryer33 Posted September 23, 2014 Author Share Posted September 23, 2014 Ah ok, interesting. It would still work on either? Having issues up top end, afrs are good and just did a ls1 coil conversion so thinking maybe the cas or tps. Any idea of signal wire voltage from closed to full open? Link to comment https://www.sau.com.au/forums/topic/448973-tps-twin-plug/#findComment-7395644 Share on other sites More sharing options...
Ben C34 Posted September 23, 2014 Share Posted September 23, 2014 (edited) Ah ok, interesting. It would still work on either? Having issues up top end, afrs are good and just did a ls1 coil conversion so thinking maybe the cas or tps. Any idea of signal wire voltage from closed to full open?Won't cause a problem..Have you increased the dwell for the coils? If you don't do that they will miss. They need 4 to 5 ms dwell. Stock is 2.5 and will cause a miss with decent boost. Voltage should be .45 closed to 4.5 (I think) open. But isn't really critical as the afm is the main load sensor. Edited September 23, 2014 by Ben C34 Link to comment https://www.sau.com.au/forums/topic/448973-tps-twin-plug/#findComment-7395649 Share on other sites More sharing options...
hairdryer33 Posted September 24, 2014 Author Share Posted September 24, 2014 Ok thanks heaps. Nah unfortunately not as im running a stock ecu for now but still is an improvement over stock. Its good in a way as im not tempted to flog it so much untill the dwell is changed, also saving fuel lol Link to comment https://www.sau.com.au/forums/topic/448973-tps-twin-plug/#findComment-7395716 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 24, 2014 Share Posted September 24, 2014 Ok thanks heaps. Nah unfortunately not as im running a stock ecu for now but still is an improvement over stock. Its good in a way as im not tempted to flog it so much untill the dwell is changed, also saving fuel lol probably why it's missing then.. gap your plugs down for the time being Link to comment https://www.sau.com.au/forums/topic/448973-tps-twin-plug/#findComment-7395798 Share on other sites More sharing options...
hairdryer33 Posted September 24, 2014 Author Share Posted September 24, 2014 Yeah done that at .8mm thanks for the advice Link to comment https://www.sau.com.au/forums/topic/448973-tps-twin-plug/#findComment-7395860 Share on other sites More sharing options...
