Honestly with that much power in mind, just get a cross flow and a forward facing plenum.
It'll make life a lot nicer when it comes to working on the car and its a lot simpler (less joins, fewer points of failure)
I tell you know, if you're going to be getting 380rwkw out of a GTST, it's going to be FAR from legal and you'll have more than a few headaches with police. Effectively turning your car and $10,000 worth of mods into a garage queen.
Just get a crossflow and get Scotty_NM35 to fab you up a pipe which can bend around the bottom of the radiator and pop up into the engine bay... No holes needed.
A big high flow turbo + E85 + Blitz return flow + factory airbox would keep you under the radar.
In the end police will always be able to find an ECU or injectors or boost controller if they want to look for them, which means anything over 170rwkw has the potential to get you found out. It's all about hiding it as well as you can. If you can keep the engine bay looking stock they won't have reason to look much further. I'd argue that any forward facing plenum is grounds to scrutinise the engine bay, versus a cooler that uses the factory piping.
But some people say blitz return flow cooler won't handle 380rkws .can only handle 250rwks
Some people don't know
I'm doing 275 with mine on a conservative dyno and I don't think it's at its limits.
If you are in Vic, keep it all looking as stock as possible. You can still make the power using ethanol as a fuel instead of dino 98.
Either a good return flow or custom piping cross flow will do the job, no need for holes to be cut. ;)
How can cops find out what ecu or injectors u got???
also i have a blitz return flow for sale if your interested :)
If cops that moody, they'll tear your car apart.
don't they need a warrant or something for that? they not really allowed to pull out the interior trims are they?
Dunno what rock you've been living in, but cops are known to take kick panel out to see what ecu the car has and some cops know what colour injector caps of cars.
Welcome to Victoria.
Plus some cops doesn't even do that and decide to send you a EPA letter and let EPA do the work.
They carry portable tool kits
Screwdriver to pop open / destroy your kick panel and look for ECU
Injectors are pretty obvious if you know the engine and certain Knox people know the standard RB25 colour is dark red/maroon
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
