i'm basically chasing a price bracket for a highmount turbo.
what have you paid and was it worth it.
i'm still pretty new to turbo cars i've owned my r34 gtt for approximately a 1yr and looking and upgrading the turbo etc
https://www.sau.com.au/forums/topic/449028-highmount-turbo-price-bracket/
It's obvious you are new. ;)
You could highmount any turbo so maybe you should be more specific as to how much power you are chasing and why you actually want a highmount. You can fit some big (400rwkw) turbos onto stock manifold.
Edited by Ben C34
haha i just don't have alot of knowledge about all this
i was looking at a Tog1 bb turbo anyone know if they are a reputable brand i got some specs for you guys to have a look at i'm not quite sure myself how responsive they are but its bb so isn't that good for starters?
what if i state whats already been done to my car will that help shed some light on the situations haha
i've already got when i bought the car turboback varex exhaust, upgraded intercooler and the rest in split fire coilpacks and larger fuel pump it's currently making 280hp with the stock ecu got nistune to go in soon hopefully, i'm basically just trying to break into the high 300's shouldn't be too hard
something like this?
http://www.hypergearturbos.com/index.php?route=product/product&path=74&product_id=69
if i've got a turbo back exhaust already does that mean my manifold has been changed most likely?
sorry for such n00b questions
That is a high flow option that uses your factory housings. Means its a 100% bolt on turbo.
If you wish to go for a simple cheap high mount that is responsive and makes good power, Go for our SL20.5. Proven performance.
http://www.hypergearturbos.com/index.php?route=product/product&path=72_76&product_id=61
Both of them will out perform the TOG item in the accounts of power v response, and reliability.
  • Like 1
Not sure how much power you are targeting. Our ATR43SS2 is made to be a bolton turbo that can support towards the 300rwkws mark on P98 fuel.
To high mount, all the hot side has to be re-made, as well as all the lines and pipping connected to the turbocharger. For a Proper high mount and external gate setup, you will be looking to spend around $1500.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
