Here's the photo I saw on facebook.
I wouldn't say it was the best in the country. A lot of that in the comments on FB. Definitely had a big social media presence though.
I Don't know what happened but here's the photo and caption.
10647062_327614034088121_233135468675826
"People say you don't know what you've got until it's gone. Truth is, I always knew exactly what I had - just never thought I'd loose it.
R.I.P - GTR99V (19/09/2014)"
As nice a car as it is/was, looking at the impact into the drivers side, he is lucky the car is dead and not him. A little bit more sideways damage and it could have been lights out.
Hopefully it was well insured.
The best
As one of the Best GTRS the country has seen or thee best
Can anyone confirm or Deny that GTR 99V is dead???
If so im shocked, the amounts of photos I have of this car
The best... it was dead stock with TE37s.... certainly a long way from the best.
Car hit a tree on a mountain run
  • Like 3
all the butt hurt gtr owners on the 'best' comment :P let it go.. i dont think it was the best and preferred it when it was completely stock. I do not like modified gtrs at all. stock as a rock, stock cd player even. that would be the best for me.
  • Like 1
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
