I have thought of that but not keen on the idea. Don't get me wrong each to their own. But the whole idea of gas flow is not to create turbulence. Regardless of how it's done it will cause some sort of turbulence. Besides I don't think I will have the room under the bonnet.
  • 2 months later...
Well finally got of my backside and finished the manifold. Now it's off to the sandblasters then coating and machine mating faces. If anyone has any other ideas or suggestions let me know. My wastegate is off the rear houseing to a 45mm turbosmart gate. Let me know your thoughts.
  • Like 1
Looks awesome mate, wish my welding was to that standard.
Changed your mind about the wastegate being positioned on the turbo?
  • 4 weeks later...
How have you sealed your v band clamp. Mine was leaking so I smeared copper max gasket silicon around the join and filled the v band clamp with silicon and placed it on let it set for 1 hour as recommended and tighten the clamp. Then found out that the wastegate was leaking too so have done the same thing.
Can't believe how much the sound of the car has changed with the new exhaust manifold and dump. Rest of the exhaust system is the same. Hope the tuner can alter the sound abit. Sounds like a rotor when I rev it. Running on all cylinders but very rich.
  • 1 year later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
