Hey all.
R34 GT-T gearbox with NPC carbotic single plate clutch. Was installed and running fine but engine died so it come out and is going on to the new engine. It looked in perfect condition when it came out.
So put it back in and now it will not disengage at all. Have bled/adjusted the pedal about 26 times now so I can confirm that it's not the issue. Pedal feel is excellent and I will attatch a video of clutch fork movement. Looking inside the box you can clearly see the release bearing pulling back the fingers of the pressure plate what looks like more than enough distance to disengage it.
As far as I am aware the only step you can gosh darn up in the install is putting the clutch itself in backwards? I didn't think it was possible but that's about the only thing I can think of.
Will having it in backwards make the clutch unable to be disengaged?
Any advice/help is appreciated. Thanks.
https://www.sau.com.au/forums/topic/449093-pull-type-clutch-wont-disengage/
Should also say that it was working perfectly with the R32 clutch master previously but won't disengage with the R33 master I now use. But by the look of these videos I'm 99% sure it's not master cylinder issue.
Okay so it's something internal. Moved the clutch fork until it hit the front of the hole cut out in the bell housing aka absolute full clutch fork travel. Still will not disengage the clutch.
What could go wrong with the pressure plate/clutch plate to cause it to still be engaged even though the release bearing is pulling on the diaphragm?
Nothing. Except for maybe it being in backwards.
Either way you aren't going to be able to fox it from the outside. Face the facts and whip the box out.
Edited by Ben C34
I know that Benny boy. Just asking if there is any known issues before I beak it open, find everything looks fine and put it all back together and have it not work.
I hope it is something as simple as clutch plate backwards but when I touch stuff it never is. Just got me stumped that it won't disengage even though the release carrier is doing it's job.
Box out.
Clutch looks good (definitely on the correct way, like I said, impossible to put single plate on backwards) pressure plate looks good, flywheel good, carrier bearing good.
Box in.
Exactly the same problem.
gosh darn.
Broken box?
Okay.
Clutch master is actuating the slave about an inch and has excellent pedal feel the entire way to the floor, so I would say that is fine.
Clutch slave has a decent amount of throw and no leaks etc, so I think that's fine.
Clutch fork is all good, not bent/cracked etc and the pivot point is all good.
Carrier bearing looked fine no abnormal marks etc.
Clutch disc itself looked fine.
Pressure plate looked fine although I wasn't sure exactly what I was looking for, just looking for general abnormalities. Also the carrier bearing is pulling on the pressure plate diaphragm and is pulling it out as it should.
So everything appears to be in a working condition.
When the car is on jackstands it can be started in any gear and the wheels turn freely and change speed with acceleration. This would indicate the part of the gearbox is fine Imagine (not sure what part as I'm no specialist). I also started the car in 1st gear and drove it around no issues.
When it was driving I was unable to get it out of first though, I was applying a decent amount of pressure on the shifter but it just didn't want to come out of first.
So yeah I have been thinking about it for the last 4 days and have not come up with a single idea that hasn't had a logical conclusion as to why it can't be that part that isn't functioning correctly.
Cash reward offered to the first person that tells me what the issue to my problem is.
"I also started the car in 1st gear and drove it around no issues." how did you do that with an engaged clutch?
Or is your problem actually "gearbox will not shift out of first" rather than "clutch will not disengage" ?
Spoke to Doug at NPC, the maker of my clutch. After I gave him all the information from the testing I have done he said the only thing it could be is a bent clutch plate. Da fark. How did that happen? Anyway.
He was kind enough to send me another one free of charge.
Put new clutch plate it and no change. Feels exactly the same as before. Can anyone recommend a gearbox place in Newcastle? I would rather slam my dick in a door for the next 48 hours than try and fix this piece of shit.
  • 1 year later...
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
