iv had cases of oil leaks before but asumed it was leaking from the oil catcher though i did get that replaced
now i noticed theres still leaks but its not coming from the catcher but from some sort of filter under the pod i think its a breather ?
iv attached a picture of how my catchcan settup is and where the leaking is from (brown shading represents oil leaks)
http://i.imgur.com/P3jxTH7.png
the catchcan itself seems literally empty
my question is why isnt the catchcan catching the oil? but passing down through the breather
The oil catch can doesn't catch the oil because it doesn't see any blow-by gases through it.
The catch can shall be between the rocker cover and the breather/intake pipe.
As is your catch can is totally useless.
ah i see this whole thing is plumbed incorrectly then and despite the several mechanics i went to about it didnt mention anything
even though the breather is before the catchcan wouldn't the can at least catch something other side of rocker cover?
i have a feeling the can might be installed incorrectly by the mechanic too lol
just figured that the breather/filter i was confused about was there to vent gases/oil to atmosphere instead of the intake
Edited by KrazyTurk
Yep that's a fairly retarded way to plumb in the catch can. It would only catch what's coming out of the inlet cam cover
How much is coming out anyway? A healthy engine none should come out.
  • Like 1
That means two things
1 your engine is tired.
2 your catch can sucks. It should be baffled.
Actually it doesn't necessarily mean 2 until such time as he sets the plumbing up properly and then oil still comes out the vent.
OP......you need the catch can to be in the path between the engine and the vent. Merge the two hoses from the cam covers together and hook them to one connection on the catch can. Connect the vent to the other port on the catch can. Run it and report back. If the can works, then there will be oil in it. If the can doesn't work (per Ben's suggestion above) then there will be oil in it and oil outside it!
worth noting that the filter/breather is a bad idea. Hook it up to the turbo intake.
1. It's illegal
2. the filter material will become soaked in oil and drip. also it's a fire hazard
3. Supposedly exposing the crank case to vacuum from the turbo will help keep the rings on their seats with a worn engine. I don't know how true this is.
4. Also if you've got blowby, and I assume you do. then boost is escaping from the combustion chamber into the crankcase where it is venting to atmosphere. typically you want this to recirculate to the turbo's inlet. I'm not sure if this would affect AFR's though
Anyway, hook up the catch can between the rocker covers and the compressor inlet. That should allow you to tick all the boxes of legality while keeping oil out of your intake
  • Like 1
  • 3 weeks later...
so i hooked everything up correctly and now noticed smoke coming out from exhaust pipe?
Ok that indicates that oil fumes are getting though the catch can so you need to baffle the catch can and/or put an air/oil seperator (could be another baffled catch can) into the line from the catch can to the turbo intake. If there is masses of oil coming out at WOT refer to the oil control thread for more answers.
When you say hooked it properly most people would take that as you hooked it up the proper way, with the catch can venting back to the inlet.
Are you sure it's hooked up properly at the moment?
That's not hooked up properly. That filter on the far right.....shouldn't be there. That hose should be hooked up to the turbo inlet pipe, so that the air that flows through the catch can into the engine has been through the AFM. We explained all that already.
It's a shame even after being told how to do it you still do it wrong, and are adamant that it's correct.
It's wrong.
Simple as that. If you don't understand that's cool, get someone who knows what they are doing to do it.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
