Hey Guys,
Up for sale is my old Exedy hyper single clutch. This was used for somewhere between 18-24 months in my 34 before a friend slipped the clutch too much at an SAU event (not good with ceramic buttons) and wore it out, So out it came making way for a twin plate. The clutch disc was a ceramic button 5 puk which ended up wearing and slipping leaving some marks on the mating surfaces.
The Good, Pressure plate and flywheel are in great nick (they need a skim before use, about $30-40) the mating surfaces are still relatively flat with less than 1mm of height variation. Very little wear on the pressure plate teeth
The Bad, needs machining before use and a new clutch disc ($140ish). I would of done this myself before selling but I really just cant be arsed. Looks worse than it really is due to the button scratching from slip.
Originally I was just going to sell the flywheel but someone might want a good power rated clutch and flywheel combo on a budget. So for under $500 you can have something that will hold 300-350kw with ease and not be a prick to drive.
Item is Located in Penrith NSW, happy for anyone to come inspect before buying. Asking price is $200 which is very reasonable seeing as the flywheel is $500 new
I can post anywhere in Aus but be mindful this thing weighs a fair bit, somewhere close to 10-15 kg so shipping may be pricey!
Contact via PM, If you wish for more pics just ask and I can either txt them or send them via PM
Pics.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
