Gday everyone,
Have been doing a bit of reading on the net but nothing has really stood out to me. Those that actually use their car for track work what offset do you use?
Looking to buy a set of 17s to use, but unsure of the best offset. Dont want to use spacers.
Im thinking something around the -10 or -20 is the go? Remembering this isnt a registered car.
Cheers
https://www.sau.com.au/forums/topic/449155-wheel-offset-for-drifting-track/
I can't remember, are you running modified knuckles? Do you happen to know what your camber, caster and SAI/KPI is? I'd probably stay away from running a negative offset, but if you want to go all out, by all means, please do. Just be sure to post pics when you do :P
Standard knuckles? 9.5+20 is about ideal on an R32. Search wheel offset calculator and plug in your rim width and try and keep your inner clearance about the same.
I had issues with my 17x9+30 R33 GTR's hitting on the chassis (as Tim knows :P)
www.1010tires.com/Tools/Wheel-Offset-Calculator
Thanks mate, guess i dont need to go with a negative offset. I just wanted to give the wheels the best chance to no scrub at full lock. Plus have a decent track for control.
Yeah standard knuckles.
Guard to tire will be the worst offender. What width wheel will you use?
I use 9.5 and find a 235/45 is too tall, will be changing to a 225/40 or a 215 if I have to, would like to stick with the 225 though.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
