Hi all
Been Meaning to join since one of you lot left a card on my car at a mighty car mods meet
Well this is my car and this is the build so far.
I bought my s14 in December 2011. It had a few mods already done to it
* body kit (hated that)
* wheels (18" by 8.5" +35 I think they were)
* FMIC
* Boost bleed valve
* 3" exhaust with centre muffler
It had a few rough points i.e
broken side skirt, rough as fark front bar. But was in otherwise good condition.
My General goal for this car was to do Targa Tasmania due to spending alot of time down there and falling in love with the race. But to also have a fun streeter that I could smash out track days in.
Car has now gone full time attack toeing the legal line for road use
mods Since I've owned the car
complete Re bushing of the car (every bush was replaced)
Tien mono flex coils
cusco rear strut bar
nismo front strut bar
DBA 3000 s14 discs
NISMO power brace
NISMO GT 1.5 way Pro LSD
Carbon center dash surround (car came with broken ones)
NISMO Extended wheel nuts (wank Factor)
Nismo extended wheel studs
Bride Euro max seats
Z32 AFM (no longer run this)
Current wheels (24/03/13) drift techs 17" by 9.5 + 20 rear with 275's 17" by 9" +15 fronts with 245's
Haltech PS1000
Apexi Power Intake (don't recommend this had to do alot of work to it to make it work like it was supposed to)
Oil Cooler with back mounted 6" thermo fan
52mm radiator with 2 12" thermo fans (no longer run clutch fan so much more space)
GK Tech oil relocation kit
Gk Tech deep dish wheel
Gk Tech brake stopper
R33 GTR front discs
Gk Teck caliper extender
Gk teck Bash Plate
Gk Teck adjustable arms (all of them)
Braided lines
Defi water temp gauge
Drift boost gauge
drift oil temp gauge
drift oil pressure gauge
pos air fuel gauge car came with
project Mu club racer pads all round (bendex ultimates while having good initial bite ended up de laminating on the track bit of an o f**k moment)
behrman d1 gp pro spec full aero body kit -technora-type
Full 6 point weld in cage
RPM 6 point harnesses
H.I.D's
Gk Tech extended diff cover
big arse GT wing (only for track days)
R33 GTR Brembo's
ATL Well cell for the e85
dash 8 lines front to back
Bride Gardis III seats
GK tech copper core rad
I.D 1000cc injectors
GTX3071r
pon cams
greddy intake plenum
Enkei P01 EVO's
Car was just Tuned by matty spry at pits
22psi and makes 415HP
Heres some pics
Parts still to go in
Haltech dash
new oil catch can set up
  • Like 1
https://www.sau.com.au/forums/topic/449160-project-ranga/
  • 2 months later...
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
