I got to mine with a 3inch exhaust basically in the way just using my 1/2 inch ratchet straight into the plug ( or a short extention can't remember)
Finding it is harder than undoing it!
Ah well the car is going onto stands soon/this afternoon. Going to change the oil in my transfer case (hasn't been done since I've owned it) and maybe have a stab at flushing my gearbox. I bought some chef synthetic atf from supercheap a while ago to do the job (says it's matic d compliant/compatible).
I ended up flagging the rear diff and serviced my transfer case instead (did it with the car on the ground reaching under).
Car's too much effort to get off the ground, doesn't go up ramps I need to drive onto blocks of wood to get a jack under it and when I jack up one end and put it on stands I can't fit the jack under the other end lol. Might leave that one to the professionals.
fkin A!
its a difficult job on the floor
plug often super tight
may need to remove cat back to get at it with enough leverage
and then you need to refill the damn thing from below, and fluid doesn't like travelling uphill.
dead easy on a hoist with the right tools
Hmm I didn't realise it was that much hassle. Ive done them quite a few times, and done it when I have the car up on 4 stands.
As I mentioned, a few flex joints helps to do the twisting outside the wheel well. Another pair of hands helps too! It's tricky keeping a floppy pole in a hole.
