38mm will be fine so long as you plan to run a decent amount of boost.
low boost + big turbo needs a bigger gate
GT35 size turbos don't really belong on a RB25 street car. a .63 rear on a GT35 turbo is a mismatch. Too much compressor, too little turbine.
GT30 with a 0.63 rear housing would be nice on the street but 0.82 will give you better top end and a few more usable top end revs.
You could always go GT30 with .63 rear and E85 + 22-24psi externally gated for around 330+ rwkw peak. usable boost would come on just before 4000 probably. That would be a mean street car
Edited by Blackkers
I agree, you can get away with a 38mm if the flow into it is optimised. Just welding it on a 90 won't cut it.
There is perhaps 200 rpm between the housings, there are also other housing options if you are going external gate. The Taiwanese stainless Tial knock offs are pretty good from my testing, and Kinugawa make some good ones in various sizes.
The kando 10cm is 1/3 of the price and gives you an inbetween size (.7x)
I've used the kando 12cm (.89) on a GT30 core and so far have found zero drawbacks. I have also seen a few in action and results indicated they did exactly what the specs implied.
Far better value in total if you buy a garrett CHRA and kando housing separately.
I've got a brand new kando gt30 12cm for sale at the moment with Vband. You should use thar ;) 150 delivered.
Also have 3076 but with internal gate .82. Don't want to seperate it.
Edited by Ben C34
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
