Hi Guys,
Thought I would write up a tutorial, as I just finished changing the clock spring in my M35. This is the most common cause of the Airbag error light flashing on the dash in modern Nissans.
First of all, the disclaimer - you take on any work at your own risk, I'm in no way responsible for damage to you or your car if you attempt this. If you don't know how to do mechanical stuff, this probably isn't for you. We are dealing with an airbag, which contains explosive material and mishandling will set it off and break your face. Right?
Backstory: OK, I have a flashing airbag error light. Unfortunately my error code reading system wouldn't read the airbag errors, only BCM and ECU related codes. So off I go to my friendly Nissan Dealer. Plugged into CONSULT, I get a B1049 Drivers Airbag module Open code.
My friendly Nissan Tech explains the most common fault from this is the Clock Sping, which is the unit that keeps the airbag electrically connected while you are swinging the wheel back and forth. In fact, by chance he has to do one on a Pathfinder that arvo (it's that common...).
Looked up the part in FAST, and ordered it. The cost is around the $180 mark incl GST from the dealership. 2 week wait ex Japan.
On to the fitting!
The only special tool you will need is a 6 pointed T30 security torx style thingo. This is to undo the airbag in the very first step. The entire process shouldn't take you more than about 1 hour. Took me a little longer taking photos and finding out shit along the way.
FIRST STEP-
Park the car on a level place, with the steering centred. Turn car off.
****DISCONNECT THE BATTERY**** this is very important cause you don't want the airbag to go off in your face. Drain the system of any residual charge via the horn, interior lights, etc etc.
Undo the two security torx bolts that hold in the airbag.
The airbag will slide out towards you. Point it away from you.
Look at the back of the airbag, using a small flathead screwdriver, gently raise the black tab on the plug, and pull the yellow connector out. Place the airbag somewhere out of the way, with the nissan badge facing upwards, not near any electrical charge.
Next unplug the yellow earth, and grey plug. Using a 19mm socket, loosen the steering wheel nut, but don't remove it completely. Pull the steering wheel towards you, this will require force, and a bit of a wiggle (or a puller if you have one...).
Place the steering wheel aside.
This is what it will look like
On the underside, remove the two phillips screws, and the cover will split in half
Now the clock spring is held on by two Phillips screws, either side, at the 8 and 4 positions. Remove the large plug from the top left if the unit, and once you have taken the screws out, remove the two plugs on the bottom of the unit, one yellow, one grey. There is a small clip on the top of the unit to hold it in place, depress and remove it.
It will then come off into your hands. You will have to change over the stalks onto the new unit. this is done by depressing two clips on either side of the stalk and pulling it out. It has a little plug that will guide you. Put them back onto your new clock spring, making sure the clip into place, and the plugs are fully seated.
Notice the new clock spring has a plastic guard over the plug. The clock spring comes pre-centred. Do not remove this until you are ready to place the steering wheel back onto the clock spring. This ensures it works for the range of motion of the wheel, and isn't 360 degrees out of alignment.
To put your new assembly back on, plug in the three plugs, and tighten the two Phillips screws. Put the yellow airbag plug through the hole in the steering wheel, and plug the yellow earth, and grey steering wheel control plug back in. Make sure you put the steering wheel back on straight- there are guide markings. Tighten the 19mm nut firmly. Tuck the wires back into their holders.
Carefully replace the airbag plug, and depress the black clip to secure the plug. Slide the airbag unit back onto the wheel, and secure it via the two torx fittings.
Connect your battery, and go and turn your ignition on, but make sure you are not sitting in the drivers seat ( do it from outside the car, incase you have farked up...). Nothing explodes...? Good.
Check all your stalk functions and horm works ok.
Now, to clear the flashing light, follow the steps found in other posts, which is basically turn ign on, as soon as you see the airbag light go off, turn ign off, wait 5 secs turn ign on again, repeat this 4 or 5 times. Start the car and the airbag light should not be flashing.
Have a beer.
  • Like 3
Great write up Alex, this is actually a really good post for how to remove the steering wheel in general actually! That's something I've been meaning to look in to, I've got a good condition spare one I've been meaning to fit; now I have no excuse not to :closedeyes:
Well! almost a couple of weeks later, no fault lights.
So problem fixed!
I suggest if you have an airbag fault, you get the code scanned, and figure out what the problem is ;)
  • Like 2
  • 3 years later...
Cheers. For the write up. Did my clock spring today, horn now works and I managed to clear the abs light after I stupidly unplugged couple things at an earlier foray with battery connected.
Thumbs up to Cockram Nissan in Christchurch, 5 mins on phone at 3pm and it was on my doorstep in Napier at 9am in morning. $340 Must be a common thing as they had three already in stock.
Might add couple pics on weekend
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
