Hey all,
Ive already searched for this but couldnt find anything of much use. How do i remove the door trims from an R32 GTSt? Ive got all 5 screws from around the edge out, as well as the plastic clip things and the big screw under the arm rest, but i cant seem to be able to remove the door handle assembly.
Not wanting to break it, how do i do it?
Also, the rear parcel shelf speaker grilles, do i just pull them off? Or are there clips or something im not seeing.
Thanks,
Rhett
https://www.sau.com.au/forums/topic/44921-help-needed-r32-door-trim-removal/
ok, the ediging on the door handles sort of pulls out. get the door handle on the inside of the car into the open door position and pull out the outer plastic.
now there is a screw hiding in the hole for pulling the door shut. It's under a plastic cap. There also another to screws behind caps near the door hinge.
U might want to take the triangle plastic bit off that sit's behind the revision mirror cus it will get a little scratched if u leave it in. Now removing all that just push the door cover up and it should come all off.
Rear parcel tray is held on buy clips from what i rember i just kept pulling mine till it came off.. After i had removed my speakers. ( My car had the alpine nfit option with speakers and all...)
U might want to take the back seat out, than u can see a bit more of what u r trying to do.
