But seriously......how long is this piece of string that you're trying to measure? Are we in 1st gear? 3rd? 5th? Uphill? Downhill?
As to the 4.9 sec 0-100 time......of course it's with a decent launch. A high rpm launch? Depends on what you cal high rpm. But realistically, on any given surface, there's only really one correct rpm to launch at, and it's not necessarily "high". ~4500rpm side stepping the clutch will get you moving fairly briskly, but the turbos won't be "fully spooled" at those revs before you let the clutch out. But they sure as hell would be if you were driving uphill in 4th.
That was my question, when are they " fully spooled." from a standing start and you say they are not fully spooled at 4500rpm in 1st. I thought they would be going hard at 4000rpm with smallish twins?
I was not really interested it those times but they were pretty quick in 1999, even now.
I didn't say "in first". Nobody launches "in first". Everybody launches with the clutch in. Ergo, the likelihood that the turbos are fully spooled up at 4000rpm BEFORE you let the clutch out and load the engine is pretty slim. The turbos will then go on to make boost once the load is applied, but you can bet your last 50c that you get full boost later (in terms of rpm) on a 1st gear launch than you would if you did a rolling start in 1st at say 1500rpm.
That's why I took the position I did on answering your question. You failed to specify exactly what you were asking about.
  • Like 1
Well each gear, peak boost will be reached at different rpm due to load, will it not?
And farken "full boost". Unless it has some sort of reference to it (eg 25 psi), it's the most meaningless thing ever. Are we talking 5 psi or 55 psi?
Oh, I'm going off a controlled environment. Dyno.
This is still silly though. I think this is a school holiday question.
Just asked when a stock R34GTR would be fully spooled from a standing start, not launched at 4500 or 8000rpm, just let the clutch out and put your foot down.
Hadouken did something strange, he just gave me the answer, going at 4k , thanks Mate
Back to school now :)
Whatever a stock standard R34GTR is, doubt if many are 5 or 55psi, you sure do swear a lot Mr Piggaz :))
Before my engine met its fourth untimely demise, I was going to ask a boost related query.
Mind you this is a 4 speed auto that's been built a lot.
1st gear would see 22psi at about 4k and bleed off to about 21.
2nd gear would see 25psi and then bleed off to about 24.
3rd gear would see 29 psi and bleed off to about 25.
4th gear (lol) would see 30psi and crack the wastegate which is what the boost controller was set to.
There were no boost leaks in the system that were obvious. There were concerns about the FMIC not liking it and maybe not flowing boost through, but it certainly made no audible sound when an air compressor was attached to the intake.
On the dyno, it made 30PSI at about 3200 RPM, in 3rd gear. The on-road experience was different.
Is this load related? The vibe I always got was that "boost is later with less load" which makes sense, but I also got that it was a few RPM difference between first gear and top gear, not multiple PSI.
Just curious to hear what others experience in 'the real world'
The general rule is exactly as you say. Higher gears mean slower ramp rates on the road, giving more time to get the gas flow up and so you make boost at lower rpm. 1st gear in particular, the ramp rate is so fast that the engine will happily accelarate through the revs faster than the turbo can spool up to give you boost. If the system is all well balanced then you get the above characteristic.
If you have a turbo with a small hot side that restricts flow, then you can actually find that you don't make more total boost in the high gears. It might still have a lower boost threshold and reach full boost earlier in those higher gears, but it might not reach the same peak boost as maybe it will in 2nd, and it may tail off more. My car with std Neo turbo tends to do that although I must admit that I haven't spent a lot of time trying to tune the gain on the boost controller to dial it out. The number of times I can usefully load the car up in high gears for long enough to be bothered by not making enough boost there are too few to cry over these days. Well, actually, the lack of such opportunities is something to cry over.
Edited by GTSBoy
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
