I want to fit an S2 RWD auto box into the S1 Dayz which is an S1 AWD that I have converted to RWD. The motor I have just fitted is an RWD type. The S2 is Tiptronic whereas the S1 is not.
Is this easily done or are there a host of mods necessary? ECU, loom etc.
Any help greatly appreciated.
https://www.sau.com.au/forums/topic/449282-s2-auto-box-into-s1/
I think you'd be better off buying an aftermarket transmission controller unit if you wish to remain auto, while adding features like tiptronic/manual gear selection. If you have cash you could look for someone selling a built box (someone on SAU was selling a RWD skyline box a while ago)
You'd also be able to control shift points and alter when the torque converter clutch locks up. You could copy the stock shift map (Im sure I have it in a PDF somewhere), and then tweak it to suit. I think the TC clutch could lock up far more often (and probably get better fuel econ as a result)
  • 4 weeks later...
just on the teptronic box i have a r34 4 door it has the tiptronic in it, i am currently building a rb 26 30 with about 400 450 bhp max will this gear box work or will i need to get a turbo box i heard someone say that the gear box dosnt talk to the ecu or some shit if you could shed some light that would be mad
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
